Re: Ebay SINTRON Kossel Mini full kit February 02, 2017 06:26PM |
Re: Ebay SINTRON Kossel Mini full kit February 14, 2017 05:17PM |
Re: Ebay SINTRON Kossel Mini full kit February 15, 2017 01:18AM |
Re: Ebay SINTRON Kossel Mini full kit February 25, 2017 01:12PM |
Re: Ebay SINTRON Kossel Mini full kit February 25, 2017 02:06PM |
Re: Ebay SINTRON Kossel Mini full kit February 25, 2017 02:23PM |
Re: Ebay SINTRON Kossel Mini full kit February 25, 2017 02:26PM |
Wibbles
Good to hear that someone else has got theirs up and running. I amazed at how fast this thing prints, my Smartrap+ has the slight edge on quality but then it does have an E3D hotend, but the Kossel will finish a job in a lot less time. Just wish it had a bigger print bed. Since discovering extra firm hairspray (on glass, no heated bed, PLA) I can print 1mm thick sheets that are 100mm+ square on either printer with no lifting, I am over the moon.
Only slight problem yet to fix, the hotend over extrudes occasionally, I have stripped it down, cleaned it right out, redrilled the nozzle, the extrusion rate is bang on 100mm, but every now and then....gloop....?
Re: Ebay SINTRON Kossel Mini full kit February 27, 2017 10:00AM |
Re: Ebay SINTRON Kossel Mini full kit February 27, 2017 10:09AM |
Re: Ebay SINTRON Kossel Mini full kit February 27, 2017 10:41AM |
If motor clicks (skips the steps) it can mean 2 things: over-extrusion or under-power. As you already tried decreasing feedrate and it was not helped, so it can be the second cause. You could try to increase power by adjusting little "+" thing on the corresponding driver board.Quote
Wibbles
I also tried slowing it down which seems to have cured it, it now runs at 80% instead of 100%. I am also trying to get that infernal clicking eradicated on the extruder mechanism. I have slowed the rate down by 60% using the lcd which doesn't affect the print quality at all, but it still has that annoying racket going on, if anyone knows how to smooth it please post up the solution. I know from my other printer that it shouldn't be doing that, as that one feeds filament silently.
Re: Ebay SINTRON Kossel Mini full kit February 27, 2017 10:47AM |
Re: Ebay SINTRON Kossel Mini full kit February 27, 2017 10:58AM |
Re: Ebay SINTRON Kossel Mini full kit February 27, 2017 11:36AM |
Re: Ebay SINTRON Kossel Mini full kit February 27, 2017 02:45PM |
Re: Ebay SINTRON Kossel Mini full kit February 27, 2017 02:57PM |
Re: Ebay SINTRON Kossel Mini full kit February 27, 2017 03:12PM |
Wibbles
This is my setting, the printer was doing exactly 100mm when I originally set it up, but slowing the rate down on the lcd didn't affect the print quality.
I went down in steps from 350 to 160, but still get the micro retracts, not as bad, but I can't get rid of them altogether.
#define DEFAULT_AXIS_STEPS_PER_UNIT {80, 80, 80, 350}
#define DEFAULT_MAX_FEEDRATE {200, 200, 200, 200} // (mm/sec)
#define DEFAULT_MAX_ACCELERATION {9000,9000,9000,9000} // X, Y, Z, E maximum start speed for accelerated moves. E default values are good for skeinforge 40+, for older versions raise them a lot.
#define DEFAULT_ACCELERATION 3000 // X, Y, Z and E max acceleration in mm/s^2 for printing moves
#define DEFAULT_RETRACT_ACCELERATION 3000 // X, Y, Z and E ma
Re: Ebay SINTRON Kossel Mini full kit February 27, 2017 03:46PM |
Re: Ebay SINTRON Kossel Mini full kit February 27, 2017 03:50PM |
Re: Ebay SINTRON Kossel Mini full kit February 27, 2017 04:01PM |
Re: Ebay SINTRON Kossel Mini full kit February 27, 2017 05:52PM |
Re: Ebay SINTRON Kossel Mini full kit March 30, 2017 03:06AM |
Sir_Death
GrAndAG
I can suggest buying solid state relay to connect heating bed via it. It will eliminate all problems with mosfet and fuse overheating.
Much cheaper (and easier) way is to just solder a wire to the Gate Signal of the internal MOSFET and place a IRF540Z external - connect Heatbed there....
Wire from RAMPS to GATE of MOSFET
"-" from Powersupply to SOURCE of MOSFET
"+" from Powersupply to Heatbed, other Wire from Heatbed to DRAIN of MOSFET
(Configuration is called "Low Side Switch")
IRF540Z does not need any cooling for up to 10Amps.. - I have no FAN blowing on it, and no Heatsink mounted.
Heatbed gets hot verry fast, IRF540 stays absolute cool, RAMPS stays cool too.
And with this config, you can easily change heatbed to 24V - just make sure "-" from both Powersupplies are connected together, and connect +24V direct to Heatbed like mentioned above...
Re: Ebay SINTRON Kossel Mini full kit March 30, 2017 04:50AM |
OG
I made this kind of a circuit and tried it and my irf540 got so f#%} HOT that I could cook sausages on it..
I had good conversation with one profesional and he said that this IRF540 is NOT a proper choise for this setup
because IRF540 needs to have 10volts for gate to get fully open and ramps gives only 5 volts so it is not fully open and if you got lucky threshold voltage is 4 volts so there is only 1 voltage to play with.. and thats why this IRF540 gets hot..
a better solution would be logic level N-channel FET instead of this IRF540..
Re: Ebay SINTRON Kossel Mini full kit April 08, 2017 09:09AM |
Re: Ebay SINTRON Kossel Mini full kit April 08, 2017 10:26AM |
Re: Ebay SINTRON Kossel Mini full kit May 05, 2017 04:19PM |
Re: Ebay SINTRON Kossel Mini full kit May 05, 2017 05:26PM |
Re: Ebay SINTRON Kossel Mini full kit May 05, 2017 06:02PM |
Re: Ebay SINTRON Kossel Mini full kit May 05, 2017 06:46PM |
Re: Ebay SINTRON Kossel Mini full kit May 06, 2017 08:03AM |
Re: Ebay SINTRON Kossel Mini full kit May 06, 2017 08:23AM |
