Re: Ebay SINTRON Kossel Mini full kit October 23, 2015 09:28AM |
Re: Ebay SINTRON Kossel Mini full kit October 27, 2015 05:13AM |
Re: Ebay SINTRON Kossel Mini full kit October 27, 2015 05:47AM |
Re: Ebay SINTRON Kossel Mini full kit October 27, 2015 04:47PM |
Re: Ebay SINTRON Kossel Mini full kit October 27, 2015 04:52PM |
Re: Ebay SINTRON Kossel Mini full kit October 28, 2015 03:44AM |
; X-tower probing G1 F4000 X-124.8 Y-72 Z20 g30 g0 z20 g30 g0 z20 g30 g0 x0 y0 z100
Re: Ebay SINTRON Kossel Mini full kit October 28, 2015 11:44AM |
Re: Ebay SINTRON Kossel Mini full kit October 28, 2015 11:58AM |
I understand how you feel. If I had to do it all over again I am confused what I would do. If you read Sintrons manufacturing it says they use UP 2 printer to print the Kossel frame? Not their own Kossel.Quote
MrPCatt
Hello everybody,
I also purchased this kit. Unfortunately before I found this thread. I wouldn't if I had seen all the problems before.
After a lot of pain mounting and cabling the thing together with its useless manual its finally done with a lot of help from this thread![]()
I used all parts provided in the kit and grinded down the rods so they move freely and don't bound and jam to each other and the mounting on the tower.
Now its calibration time witch drives me nuts. Basically its not working at all for me. Especially the autoprobe is a joke and constantly cashes the head onto the bed and on the sides.
I don't understand why Sintron just don't provide a working firmware where just the delta z for the height and the length of the rods needs to be adjusted. All other values should be the same or not? The manual says I have to measure (exactly) different parts where its not clear for me from where to where I have to measure.
My question to you guys is if anybody has a realy working firmware for me where I just have to correct the height and the rod length to finally start printing anything?
Any help much appreciated!
Re: Ebay SINTRON Kossel Mini full kit October 28, 2015 12:01PM |
MrPCatt
Guys, thank you for your help!
So i measured several things again and uploaded a new firmware, mounted a fresh roll of PLA and now I wanted to give it a try to see if I am even close to print something (without Z-Probe).
BUT
The filament is not coming out of the nozzle. Its just dripping ever so slightly, never ever enough to draw a line or so. The extruder motor is just stuttering because the pla is not going forward, something seems jammed or so. The screw for the pressure on the roll of the extruder motor is set to max. Temperature is set to 205. Fan is on all the time. I can pull the pla stripe back out, and it looks normal to me.
Omg, what is this now? Is the extruder jammed even before the first print? How can I fix this?
Re: Ebay SINTRON Kossel Mini full kit October 28, 2015 12:08PM |
MrPCatt
BUT
Re: Ebay SINTRON Kossel Mini full kit October 28, 2015 12:51PM |
MrPCatt
BUT
Re: Ebay SINTRON Kossel Mini full kit October 28, 2015 01:23PM |
DRTak
I would never know what I know now if I had just bought a pre assembled printer. I actually think I would be bored with the whole idea. But part of the fun and frustration is figuring out calibration and fine tuning.
hacker
I wonder can you also push the filament? As in hand-extrude? I think the hotend came preassembled, so there's no way you could incorrectly assemble it, right? If only not sticking ptfe tube deep enough?
xile6
Is it hard to pull the filament out?
And is it hard to put it back in?
DRTak
However, you really really should tightened the hot end nozzle with a wrench or you will leak out filament all around the sides and get burnt PLA around the hot end tip.
, but at least finally something
Re: Ebay SINTRON Kossel Mini full kit October 28, 2015 02:09PM |
MrPCatt
DRTak
Thats the reason I decided to go with a kit instead of buying something out of the box. Its all about introducing myself into the matter of 3D printing. The journey is the reward. Actually I don't really have a need for 3D printer parts at all.
But this kit is a bit overkill. I did not want to re engineer everything this with endless hours on google and knowledge bases
hacker
I wonder can you also push the filament? As in hand-extrude? I think the hotend came preassembled, so there's no way you could incorrectly assemble it, right? If only not sticking ptfe tube deep enough?Quote
xile6
No, i could not push it in our by hand, no chance.
And yes, everything was preassembled....
And i sharpened the tip a little bit.
Not sure what the cause was, but I got it free for now.
Maybe something similar to what DRTak said, a head-crash bend the nozzle or so.
I took the noozle of and cleaned it with the help of a torch and a needle as good as I could.
DRTak
Yes I did tighten it with a wrench, and yes, it was still to little and now burned pla is all around the nozzle. Guess I have to take it out again
But guess what, I actually could print something out. What a reward...
Of corse its far from good. My 10mm calibration cube is x/y 11.2mm., but at least finally something
Re: Ebay SINTRON Kossel Mini full kit October 28, 2015 04:45PM |
Re: Ebay SINTRON Kossel Mini full kit October 29, 2015 04:06AM |
Re: Ebay SINTRON Kossel Mini full kit October 29, 2015 02:44PM |
Re: Ebay SINTRON Kossel Mini full kit October 29, 2015 03:55PM |
Tha_Reaper
I used that sites method... i told the printer to reverse 30mm of filament. The result was 251mm reversed. I think i found out what caused my extruder to skip and my cube to become a blob
Re: Ebay SINTRON Kossel Mini full kit October 29, 2015 04:12PM |
Re: Ebay SINTRON Kossel Mini full kit October 29, 2015 04:16PM |
Re: Ebay SINTRON Kossel Mini full kit October 29, 2015 04:22PM |
Re: Ebay SINTRON Kossel Mini full kit October 29, 2015 04:24PM |
dc42
91 steps/mm is very low. What sort of extruder do you have? If it is a direct drive (non-geared) extruder, then 91 steps/mm might just be correct. If it is a 3:1 geared extruder then the steps/mm should be more like 400, in which case an actual value of 91 means you have the microstepping set too low.
Re: Ebay SINTRON Kossel Mini full kit October 29, 2015 05:35PM |
That's correct. As I don't know a lot about marlin and coding I decided just to change the first part. Didn't know if the *1.1 was some kind of required part...Quote
hacker
IIRC, Marlin's stock Configuration.h has 760*1.1 for extruder steps? Could it be that you changed it to 91*1.1? That would make 100.1 which is closer to 104.something I got after calibrating. Because 91 indeed sounds a bit low.
Re: Ebay SINTRON Kossel Mini full kit October 30, 2015 06:23AM |
Tha_Reaper
hacker
I still need to fix a couple of things... Like a good bed leveling mechanism and adjustment screws on top of my carriages... I can't find screws that are suitable for that. Also my z probe sucks. It just doesn't want to work and gets stuck every bloody time. I will try more tinkering but I really expect that I'll need to ask here for more help on that soon.
Re: Ebay SINTRON Kossel Mini full kit October 31, 2015 01:26PM |
Re: Ebay SINTRON Kossel Mini full kit October 31, 2015 04:56PM |
Re: Ebay SINTRON Kossel Mini full kit October 31, 2015 07:37PM |
Re: Ebay SINTRON Kossel Mini full kit November 01, 2015 02:57AM |
Re: Ebay SINTRON Kossel Mini full kit November 01, 2015 02:35PM |
Re: Ebay SINTRON Kossel Mini full kit November 01, 2015 03:06PM |
DRTak
So If I dont use an Arduino Ramps. How do I use my Kossel? What other system can run it.
Re: Ebay SINTRON Kossel Mini full kit November 01, 2015 03:37PM |
