Re: Ebay SINTRON Kossel Mini full kit February 17, 2016 10:37AM |
Re: Ebay SINTRON Kossel Mini full kit February 17, 2016 11:22AM |
Re: Ebay SINTRON Kossel Mini full kit February 17, 2016 11:24AM |
CrisCG
Yes, strange. I sent them a message.
About the fan issue, maybe the fan is the problem. When i send M106 command, it wants to move, gets an impulse, like 1/10 of a turn or something, then stops.
Re: Ebay SINTRON Kossel Mini full kit February 17, 2016 12:01PM |
Re: Ebay SINTRON Kossel Mini full kit February 17, 2016 01:18PM |
Re: Ebay SINTRON Kossel Mini full kit February 18, 2016 09:29AM |
Re: Ebay SINTRON Kossel Mini full kit February 18, 2016 09:34AM |
CrisCG
Bought another fan and it works.
But i managed to clog the nozzle in the first print. Great, how do i unclog it?
Re: Ebay SINTRON Kossel Mini full kit February 18, 2016 02:09PM |
Re: Ebay SINTRON Kossel Mini full kit February 18, 2016 03:04PM |
Re: Ebay SINTRON Kossel Mini full kit February 18, 2016 03:22PM |
Re: Ebay SINTRON Kossel Mini full kit February 18, 2016 03:28PM |
Re: Ebay SINTRON Kossel Mini full kit February 18, 2016 05:07PM |
Re: Ebay SINTRON Kossel Mini full kit February 18, 2016 06:59PM |
Re: Ebay SINTRON Kossel Mini full kit February 18, 2016 08:08PM |
However, since I need to do quite a bit of work before that setup works, I have refrained from taking up that challenge yet.|
Re: Ebay SINTRON Kossel Mini full kit February 19, 2016 03:27AM |
gkr
Hello Experts,
Since the current topic appears to be related to calibration...
I never got the Auto-Z-Probe to work properly, and had a few instances when the z-probe unexpectedly engaged in the middle of a print.
So, when I switched over to the E3D Hot-end, I removed the Z-probe altogether, and ended up manually calibrating the print-bed (mounted on springs) as much as I could.
Now after getting the Extrusion and Retraction settings all golden, I'm getting very decent prints.
The other day when I was browsing thingiverse, I found this:
[www.thingiverse.com]
Has anyone tried the above by any chance on this Sintron setup?
Re: Ebay SINTRON Kossel Mini full kit February 19, 2016 08:13AM |
AFAIR, FSRs do not like heat. Regular FSR's usually can handle PLA temps (<60C), but nor more. They likely will not be damaged, but readings will be inaccurate.Quote
gkr
BTW, I also saw some FSRs at my local Microcenter, so I picked them up. They had exactly 3 of themHowever, since I need to do quite a bit of work before that setup works, I have refrained from taking up that challenge yet.
Re: Ebay SINTRON Kossel Mini full kit February 19, 2016 10:48AM |
gkr
Hello Experts,
Any comments are appreciated.
Regards.
Re: Ebay SINTRON Kossel Mini full kit February 19, 2016 10:50AM |
DRTak
I stopped using the auto deploy feature because I had a feeling it was loosening the Z belt when it was ramming the L probe part over and over to auto deploy. Multiply this by the number of prints I did in a day and I didnt want to take a chance. I also removed the plastic spring holder. It would get loose to often and lose tension on the spring.
Re: Ebay SINTRON Kossel Mini full kit February 20, 2016 02:46PM |
Re: Ebay SINTRON Kossel Mini full kit February 20, 2016 08:26PM |
Re: Ebay SINTRON Kossel Mini full kit February 21, 2016 02:44AM |
Re: Ebay SINTRON Kossel Mini full kit February 21, 2016 07:28AM |
Re: Ebay SINTRON Kossel Mini full kit February 21, 2016 11:45AM |
Re: Ebay SINTRON Kossel Mini full kit February 22, 2016 01:49AM |
DRTak
anyone try printing with taulmann Bridge nylon on the kossel. I am going to buy some filament since I want an indestructable part. My kids break all of the PLA and ABS toys I make them.
Re: Ebay SINTRON Kossel Mini full kit February 22, 2016 10:30AM |
o_lampe
DRTak
ABS can be cured with acetone to make it durable like LEGO.
Don't keep the acetone in kids range
Re: Ebay SINTRON Kossel Mini full kit February 25, 2016 04:45AM |
Re: Ebay SINTRON Kossel Mini full kit February 25, 2016 08:36AM |
CrisCG
Hi everybody. Here's a video of what happens with the Sintron supplied rods, the ends rub against each other -> Click here. Sintron support insists that they don't interfere.
Those steel rods have a lot of play, they're not as stiff as the carbon tube + traxxas ends, wich i recently switched to.
Re: Ebay SINTRON Kossel Mini full kit February 25, 2016 09:14AM |
Re: Ebay SINTRON Kossel Mini full kit February 25, 2016 11:13AM |
Re: Ebay SINTRON Kossel Mini full kit February 25, 2016 02:22PM |
