Printer wants to start print wayyyyy off printing areasad smiley
Posted by heyitsbenb
August 05, 2015 04:07AM
I'm working on getting my printer to make simple movements. To test some simple movements I added some simple GCODE to move in a straight line on the X and Y axis. But for some reason, my printer thinks it has to move a huge distance before it does that (See the Green line on the page). The GCode is pretty straight forward so the issue isn't there. Next i thought that the printer configurations werent centered at the origin but i can't seem to find where this would be stored.
Does anyone know what could be going on here?
My GCode is super straightforward, it should just move down and make a cross. For some reason it wants to move left a looooong distance first
G1 Z-20
G1 X30
G1 X-30
G1 X0
G1 Y30
G1 Y-30
G1 Y0
G1 Z0
open | download - Screenshot 2015-08-05 01.07.16.png (53.8 KB)
Re: Printer wants to start print wayyyyy off printing areasad smiley
August 05, 2015 09:06AM
maybe try a G28 as the first command to home the printer?
August 05, 2015 12:34PM
I don't have my end stops configured yet, so I won't be able to home :/
Edited 1 time(s). Last edit at 08/05/2015 12:35PM by heyitsbenb.
August 05, 2015 01:57PM
What positioning mode is set by default?
G90        ;absolute positioning
G91        ;relative positioning
-Olaf
August 07, 2015 09:36AM
Try to set your slice starting location to 0,0 if you are using a delta printer. I had the same issue when I started printing with mine. Some slicer assume you have rectangle printing bed and starts to print at the center (i.e. 70,70), causing out of bound errors.
