My printer has a heated chamber set to 50c. The first few prints have been stable enough. Since I replaced a bunch of components on the printer now I am dialing it in. As of now I heat the bed to 100c and nozzle to 245c as well as set the chamber temp to 50c. However the temperature gradient on the chamber is not so good right now as my heater is ontop of the printer and the hot air is not being pushed downward. I had a failed print last night with the bottom layer delaminating. That did not make me happy, however the jury is still out on the cause. I had a small leak on my nozzle and ended up tightening it. That could easily shift .2mm up. I am going to calibrate the printer at full temp soon enough as well as mount a mixing fan on the printer to even out the temperature gradient. Looking at doing this work tonight. I will most likely do a follow up video for these sensors as well. I may just implement the auto leveling probe on this printer using a precision ground 4mm shaft I have laying around.
My Personal Blog. Build blog.
engineerd3d.ddns.net]
Modicum V1 sold on e-bay user jaguarking11
