Re: I am begging you for help with my Rostock Delta August 16, 2015 08:29AM |
LarsK
That makes no sense. If it is a problem with diagonal rod length it should be increasing the length that works.hmm strange :/
Still, if your misalignments are less then 0.5 mm then you can now set the bed height so that the nozzle is too low.
Simply I want you to increase MANUAL_Z_HOME_POS by 0.3.
That means it won't exteude plastic on the first layer in some places while it will in others. This is OK.
Try that out if you can print something now.
Then go find a z probe mount to print and install that. I am afraid we won't get much further with pictures of sd cards then where we are now.
Re: I am begging you for help with my Rostock Delta August 17, 2015 05:09AM |
Re: I am begging you for help with my Rostock Delta August 17, 2015 07:29AM |
Re: I am begging you for help with my Rostock Delta August 17, 2015 08:28AM |
LarsK
It has two names. One in the configuration.h and a different one in EEPROM.
It is OK if you have been recompiling - It is faster to set in the EEPROM but if you don't note down your changes you may lose them if changing something.
Re: I am begging you for help with my Rostock Delta August 17, 2015 10:47AM |
Re: I am begging you for help with my Rostock Delta August 17, 2015 10:58AM |
Re: I am begging you for help with my Rostock Delta August 18, 2015 12:12PM |
LarsK
I should add that when I asked you to lower the Z height by 0.3 it had nothing to do with calibration. It is just a dirty trick to level out the errors. The nozzle does not go lower then the bed - Bue due to slack in the system you can push it onto the bed so that the software thinks that it is 0.3 mm lower then what it actually is.
As such; Lowering the nozzle lower then when it is perfect in X0 Y0 is something you do to negate the last bits of misalignment, that you were not able to solve playing with the parameters.
Repetier has a more refined way to do this with a Z probe where it creates an off-set map that combats misalignment's much more dynamically. At the end of the day it is symptom treatment with the actual root cause being poor alignment/calibration.
Re: I am begging you for help with my Rostock Delta August 19, 2015 07:03AM |
