Re: Has any one built the Micromake printer? September 30, 2015 02:40PM |
aimatt
Thanks for the help. I did the gcode and it does switch to closed when pressed. So so all the endstops appear to trigger correctly. Doesn't that mean the nozzle shouldn't smash into the glass like it has been? Or is it just used for the probe? How do you do the probe?
I'll check on max z length.
Re: Has any one built the Micromake printer? September 30, 2015 03:35PM |
Re: Has any one built the Micromake printer? September 30, 2015 04:10PM |
Re: Has any one built the Micromake printer? September 30, 2015 06:32PM |
Re: Has any one built the Micromake printer? September 30, 2015 07:12PM |
aimatt
Is the aluminum to help heat up faster? With the glass it's taking 30 mins or more to get to 110 degrees.
Re: Has any one built the Micromake printer? October 01, 2015 10:49AM |
Re: Has any one built the Micromake printer? October 01, 2015 11:14AM |
Re: Has any one built the Micromake printer? October 01, 2015 12:51PM |
Re: Has any one built the Micromake printer? October 01, 2015 01:04PM |
I did all that in the firmware. Your have to upload it to the board with all the readings you took.Quote
aimatt
Sorry to backtrack, but I'm having trouble setting the z max height. I tried M206 Z16 but doesn't appear to take when checking with M501. How did you set it?
Re: Has any one built the Micromake printer? October 01, 2015 01:24PM |
Re: Has any one built the Micromake printer? October 02, 2015 01:12PM |
Re: Has any one built the Micromake printer? October 02, 2015 01:37PM |
Re: Has any one built the Micromake printer? October 02, 2015 02:56PM |
Check your endstop.Quote
aimatt
When it does the autolevel, it does it like 4-5 inches over the bed. Shouldn't it do it near bed level so it can detect slopes?
Re: Has any one built the Micromake printer? October 02, 2015 05:02PM |
Re: Has any one built the Micromake printer? October 02, 2015 06:15PM |
aimatt
Yeah, that is what it is showing....
Re: Has any one built the Micromake printer? October 03, 2015 11:14AM |
Re: Has any one built the Micromake printer? October 03, 2015 11:35AM |
aimatt
Yeah it is center, about 5mm up. I moved my top endstops down, thinking there might be some macro set, limiting the amount of travel or something. That improved, resulting in getting close to the bed. However, when it moved to the side, it scraped into the bed in the -X direction, in the +X direction, it lifted off the bed. I played manually with Pronterface and it seems like either the bed is not level, or the extruder moves slanted. I used the spacer method to mount the bed, so there's no real way to adjust it as is.
Could different arm lengths cause this? I did not check them initially and some of the squeaking and noises I alleviated by lengthening a couple out them by unscrewing the bearing a bit.
Re: Has any one built the Micromake printer? October 03, 2015 03:19PM |
Re: Has any one built the Micromake printer? October 03, 2015 03:27PM |
Re: Has any one built the Micromake printer? October 03, 2015 04:04PM |
Re: Has any one built the Micromake printer? October 03, 2015 04:37PM |
Re: Has any one built the Micromake printer? October 03, 2015 10:00PM |
Re: Has any one built the Micromake printer? October 03, 2015 10:15PM |
aimatt
Wow. You were right about the end stops. Turns out there was a bad solder job on the wires to the switch. I was broken off. Since it's under heatshrink, it would work in the home position normally. However, when it went lower it would disconnect. With your firmware, it's working perfectly. Thanks so much!!!
Re: Has any one built the Micromake printer? October 04, 2015 08:35AM |
Re: Has any one built the Micromake printer? October 04, 2015 08:51AM |
Re: Has any one built the Micromake printer? October 04, 2015 09:30AM |
aimatt
Maybe a new problem.... my nozzle might be gunked up or something, the filament comes out really slow. I'll try a higher temp I guess.
Re: Has any one built the Micromake printer? October 05, 2015 11:36AM |
Re: Has any one built the Micromake printer? October 05, 2015 12:13PM |
I didnt change the frist laryer settings.Quote
aimatt
I'm using ABS. PLA was not really an issue. I was able to print one part with no heated bed with PLA. I was able to get better flow with 245C, but it just seems like there is a lag. Like the whole first layer just has nofilament come out.
Using cura, do you set the first layer thickness and speed? So far, lowering those seems detrimental.
The fan is on the extruder, blowing at it.
Re: Has any one built the Micromake printer? October 05, 2015 10:14PM |
Re: Has any one built the Micromake printer? October 09, 2015 12:25PM |
