Re: Has any one built the Micromake printer? November 07, 2015 04:05PM |
Re: Has any one built the Micromake printer? November 07, 2015 05:05PM |
Re: Has any one built the Micromake printer? November 07, 2015 05:18PM |
Re: Has any one built the Micromake printer? November 07, 2015 05:33PM |
Re: Has any one built the Micromake printer? November 09, 2015 04:33PM |
Re: Has any one built the Micromake printer? November 12, 2015 04:20PM |
edak
Can anyone identify how a motor could skip in the same direction then back again so regularly? I would think that motor skips would look more random than this.
Still puzzled...
Re: Has any one built the Micromake printer? November 12, 2015 04:49PM |
Re: Has any one built the Micromake printer? November 12, 2015 07:16PM |
Re: Has any one built the Micromake printer? November 13, 2015 01:31AM |
Re: Has any one built the Micromake printer? November 15, 2015 08:15AM |
Re: Has any one built the Micromake printer? November 17, 2015 05:01PM |
Re: Has any one built the Micromake printer? November 19, 2015 05:37AM |
Re: Has any one built the Micromake printer? November 19, 2015 08:09AM |
Re: Has any one built the Micromake printer? November 20, 2015 02:13AM |
Re: Has any one built the Micromake printer? December 02, 2015 11:15PM |
Re: Has any one built the Micromake printer? December 19, 2015 09:26AM |
Re: Has any one built the Micromake printer? December 19, 2015 10:07AM |
Re: Has any one built the Micromake printer? December 19, 2015 06:03PM |
Re: Has any one built the Micromake printer? December 19, 2015 06:34PM |
aeonfox
Hello
I am lookling for a bit of help with my micromake. I got it working fine after a few minor issues, and had it printing a number of parts that I was happy with.
However the hotend jammed up, and during the course of figuring out the problem the feeder that came with it broke.
I replaced the feeder with a aluminium one, and have that working, but I still had problems with it jamming, so i have got a E3D V6 J-head 1.75mm.
I am not convinced that it is heating to the correct temperature. Is there a setting i need to change?I looked up a spec on the internet, and it has 100K specifiction for the thermistor. If I wanted to measure how hot the heater block is getting, can i just put a digital thermometer on the block and use the temperature i read there?
Based on the above comments, I will next install the RC firmware and figure out that app.
Craig
Re: Has any one built the Micromake printer? December 20, 2015 04:57AM |
Re: Has any one built the Micromake printer? December 20, 2015 06:05AM |
Re: Has any one built the Micromake printer? December 20, 2015 08:11PM |
Re: Has any one built the Micromake printer? December 29, 2015 03:11PM |
Re: Has any one built the Micromake printer? January 03, 2016 09:45AM |
Re: Has any one built the Micromake printer? January 03, 2016 10:16AM |
megamicro
hi there,
i too just built a micromake printer.
looks nice, but i should focus on other things about at the time being.
problems:
- upon completion, the firmware on it or the controller card itself just locked up.
that only happens when i attempted to jog the motors positions.
it would allow it to happen a little, then it would just lock the screen, the dial on the controller became useless.
a reboot of the card seems to reset it back to retrying the same scenario repeatedly.
- a attempt to home the printer causes only two of the three motors to respond properly.
one motor would move only in one direction after reaching the limit switch.
if i performed a 2nd or a 3rd attempt, it would get increasingly less calibrated with that one motor, as that motor would avoid going near the limit switch each time a little further away.
i turn it off, retry, same results.
that same motor became very warm, unlike how the others are.
i am convinced the controller card itself is buggered for that particular motor driver on its board.
it could be a result of both a bad controller card and one bad motor.
also only one of the two fans will work.
i did attach the 2nd fan into the correct socket on the board as shown in the videos the seller provided me with, correct + and - fan wires identified before installing.
the quality control testing sticker on the card suggests it passed its testing. hmmm...
that makes me wonder how in depth the testing goes before getting a stamp of approval then being shipped to a customer.
its been a few days since the printer kit arrived, and will consider contacting the seller on ebay.
- the instructions were not english, in fact there was no instructions included in the packaging.
i contacted the seller to inform that instructions were needed, and then was provided a link to only chinese instructions shown on video.
even though rewinding it alot to try and decode the instructions, i managed to build most of the machine prior and without any examples to follow.
i found this forum here shortly afterwards. lol
i am always very careful handling electronics, and never bumped or did anything to the delicate items.
i treat it like a neurosurgeon would.
another thing that seems spooky, is how the seller routes the end stop wires.
the wires are expected to be in rather close proximity to the knife sharp edges at the top of the aluminum extrusions, you too most likely noticed this too.
and the extrusions could have had better protection in the box by wrapping them individually, there are small dings present on them that breach the painted finish. that could have been avoided and most likely will be in the future by who is responsible for packaging them prior to shipping.
i do happen to have an extra arduino with the ramps 1.4 board i purchased a few months ago before buying the delta that is intended for another larger build of a machine, and am wondering if and how i should install that one to replace the defective one that came with this micromake delta printer.
the ramps version came with opto end switches, rather than the mechanical ones, so that means the inputs on the micromake card do not allow it to match up.
the micromake end stops using only 2 connections, while the optical ones are wanting 3 of them.
kinda stuck wondering my next move.
has anyone else encounters similar concerns with their micromake printers?
wish i had a smoothie board based on what people say about that one.
but really, the micromake card and that one motor should be working without needing instant replacement$.
anyone have any solutions for how to configure the ramps card to replace the micromake one?
has anyone ever had to ask micromake for a new controller card, and or a new nema 17 motor?
also, there was no mounting system for filament spools, i thought there would be one based on the pictures they advertised that showed the spool parked on top of the delta printer.
thankyou for reading this and any help offered.
may all your prints turn out exact.
Re: Has any one built the Micromake printer? January 03, 2016 01:42PM |
Re: Has any one built the Micromake printer? January 04, 2016 12:24AM |
Re: Has any one built the Micromake printer? January 08, 2016 10:34PM |
Re: Has any one built the Micromake printer? January 09, 2016 12:06PM |
Re: Has any one built the Micromake printer? January 09, 2016 12:34PM |
