Re: Just built one, still calibrating… August 09, 2016 04:40PM |
Re: Just built one, still calibrating… August 12, 2016 02:44AM |
#define DELTA_DIAGONAL_ROD 216 // 217.3 mm #define DELTA_SMOOTH_ROD_OFFSET 157 // 151 mm #define DELTA_EFFECTOR_OFFSET 32 // 24 mm #define DELTA_CARRIAGE_OFFSET 31 // 22 mm #define DELTA_RADIUS (DELTA_SMOOTH_ROD_OFFSET-(DELTA_EFFECTOR_OFFSET)-(DELTA_CARRIAGE_OFFSET)) #define DELTA_PRINTABLE_RADIUS 85 // 90mmHow do these compare with the settings other owners of this machine are using?
It's finally done... (or is it?).... August 17, 2016 08:59PM |
Re: Has any one built the Micromake printer? September 13, 2016 02:15AM |
Configured Marlin 2016-09-19 September 19, 2016 02:45AM |
Henrik B
Also thinkyhead do you have a working configuration.h or firmware for the latest marlin firmware you can share?
Re: Has any one built the Micromake printer? September 26, 2016 07:29AM |
Re: Has any one built the Micromake printer? October 07, 2016 06:36PM |
. Not even Cura, which comes with the machine and runs ok on the PC. Any ideas? Another forum suggested the firmware needed updating, but I am not comfortable trying that just yet. On the Mac, Cura, Repetier Host, and Matter Control, all see the printer in the setup section, but refuse to connect to it. Changed the baud speed, rebooted, re-installed, changed cables, running out of options. Help!!
Re: Has any one built the Micromake printer? October 09, 2016 09:37AM |
Re: Has any one built the Micromake printer? October 10, 2016 07:29AM |
Re: Has any one built the Micromake printer? October 10, 2016 06:19PM |
Re: Has any one built the Micromake printer? October 11, 2016 06:14PM |
Re: Has any one built the Micromake printer? October 12, 2016 07:36PM |
Re: Has any one built the Micromake printer? October 15, 2016 04:56AM |
Re: Has any one built the Micromake printer? October 15, 2016 08:36AM |
Re: Has any one built the Micromake printer? October 15, 2016 09:39AM |
Re: Has any one built the Micromake printer? October 15, 2016 10:02PM |
Re: Has any one built the Micromake printer? October 16, 2016 07:47PM |
8perf
Anybody know if it is possible to insert a geode command somewhere into the firmware or the cura settings to disable the heated bed after the first 10 layers or so. Concerned that the heat from the bed may damage the electronics in the long run, being so close to the wires and all. Have a card stock shield in place now, but would still like a software fix if possible.
Re: Has any one built the Micromake printer? October 17, 2016 05:17PM |
Re: Has any one built the Micromake printer? October 17, 2016 07:42PM |
Re: Has any one built the Micromake printer? October 18, 2016 07:16AM |
Re: Has any one built the Micromake printer? November 01, 2016 08:38PM |
Re: Has any one built the Micromake printer? November 01, 2016 09:22PM |
Re: Has any one built the Micromake printer? November 03, 2016 07:54AM |
Re: Has any one built the Micromake printer? November 03, 2016 08:09AM |
Re: Has any one built the Micromake printer? November 03, 2016 09:30AM |
Re: Has any one built the Micromake printer? November 03, 2016 08:32PM |
siddharta
That's what I did with the power wires of the heated beds on the two Prusa's, the original wiring was an accident waiting to happen. I also had to swap out the power connector on one of the Chinese RAMPS boards for a genuine Molex and replace the heatbed MOSFETs for same reason.
Re: Has any one built the Micromake printer? December 29, 2016 10:21AM |
Re: Has any one built the Micromake printer? December 29, 2016 07:08PM |
