Re: Has any one built the Micromake printer? January 15, 2016 03:57PM |
Re: Has any one built the Micromake printer? January 15, 2016 03:58PM |
Re: Has any one built the Micromake printer? January 15, 2016 04:02PM |
Re: Has any one built the Micromake printer? January 15, 2016 04:53PM |
Re: Has any one built the Micromake printer? January 15, 2016 07:37PM |
Re: Has any one built the Micromake printer? January 15, 2016 08:45PM |
Re: Has any one built the Micromake printer? January 15, 2016 09:30PM |
scottman85
i tried all the versions of firmware shared and non of them have the functionality of the original firmware shipped with my machine.
i have the one with the injection molded parts and i think it shipped with a newer revision of firmware. my computer os is ubuntu
so couldnt use any of the software from the manufacture download site to calibrate the Z. Thinking I could get it working with different firmeware, I tried the ones shared with failed results
and now I cant get back to my original because mine never shipped with an sd card with firmware on it.
Mine said micromake ready on the lcd and the board is model 1.2.
If anyone has this firmware i would greatly appreciate it.
Thanks
Re: Has any one built the Micromake printer? January 16, 2016 12:09AM |
Re: Has any one built the Micromake printer? January 16, 2016 12:50AM |
Re: Has any one built the Micromake printer? January 16, 2016 12:56AM |
Re: Has any one built the Micromake printer? January 16, 2016 10:39AM |
Re: Has any one built the Micromake printer? January 16, 2016 02:07PM |
xile6
What is your G30 A print out?
Should be 7 numbers.
And you dont run G30 A before ever print only G28 then G29.
And G28 overrides G29. This is for any type of 3d printer.
Re: Has any one built the Micromake printer? January 16, 2016 08:59PM |
hoang82
xile6
I know you dont run G30 before printing.
Good to know G28 overrides G29.
I am also thinking of ideas to replace the effector that comes with the new printers. It's a cool design, but it's constantly blowing air down towards the print surface. So printing in ABS is a pain. I might try and reverse the fan direction so it pulls air from the bottom and out the top and see if that works.
I'm also having problems with printing PLA. Seems like the fan isn't supplying enough power since it's using PWM. Even at max speed 255 pwm, I barely feel any air coming out of the fan. I ended up having to manually hold a 50mm Blower fan to the printed part when printing PLA. Any ideas on how to speed up the fan other than directly connecting it to the 12v PSU?
M666 L Values:
19:01:43.393 : Current Delta geometry values:
19:01:43.397 : X (Endstop Adj): -2.21
19:01:43.397 : Y (Endstop Adj): -2.35
19:01:43.397 : Z (Endstop Adj): -1.47
19:01:43.401 : P (Z-Probe Offset): X0.00 Y0.00 Z0.50
19:01:43.401 : A (Tower A Position Correction): 0.08
19:01:43.401 : B (Tower B Position Correction): 0.14
19:01:43.405 : C (Tower C Position Correction): -0.22
19:01:43.405 : I (Tower A Radius Correction): 0.37
19:01:43.409 : J (Tower B Radius Correction): 0.37
19:01:43.409 : K (Tower C Radius Correction): 0.37
19:01:43.409 : R (Delta Radius): 92.16
19:01:43.413 : D (Diagonal Rod Length): 207.61
19:01:43.413 : H (Z-Height): 319.81
Also does anyone happen to know where I could connect a servo to the board, or do you know where pin D11 is? I want to install a different type of auto leveling probe instead of using Micromake's design. All the nozzle tapping on the glass bed seems like the nozzle took a good beating. I want to eliminate the nozzle touching the bed.
Re: Has any one built the Micromake printer? January 16, 2016 09:10PM |
Re: Has any one built the Micromake printer? January 16, 2016 10:46PM |
Re: Has any one built the Micromake printer? January 17, 2016 12:10AM |
Re: Has any one built the Micromake printer? January 17, 2016 01:21AM |
Hownis the bed mounted?Quote
hoang82
yeah so i need to read up on the firmware and see if I can use the D2 pin for the servo signal wire. but if there is a D11 pin somewhere on the board, I can just wire it from there with 5v else where..
anyway,, so far I have ran 3 G30 A calibrations and I'm getting the same results everytime. Z side of the axis is too low and the XY is too high. I thought G29 auto bed level should fix this. I'm running out of ideas.
Re: Has any one built the Micromake printer? January 17, 2016 01:34AM |
Re: Has any one built the Micromake printer? January 17, 2016 05:17AM |
Re: Has any one built the Micromake printer? January 17, 2016 07:48PM |
Re: Has any one built the Micromake printer? January 18, 2016 02:30AM |
Re: Has any one built the Micromake printer? January 18, 2016 02:49PM |
Re: Has any one built the Micromake printer? January 19, 2016 02:29AM |
Re: Has any one built the Micromake printer? January 20, 2016 02:26AM |
Re: Has any one built the Micromake printer? January 20, 2016 11:29PM |
Re: Has any one built the Micromake printer? January 21, 2016 01:24PM |
Re: Has any one built the Micromake printer? January 21, 2016 09:42PM |
hoang82
So I was able to finish G30 A finally. I had thr probing speed too high.
I can print the center of the bed but thr very edge, its a tad high at Z and a little low on X. Looks like it still need to go in and manually correct endstops. I've squared up everything as much as possible. So im feeling that the G30 A could not accuratly calibrate.
Re: Has any one built the Micromake printer? January 21, 2016 11:15PM |
Re: Has any one built the Micromake printer? January 22, 2016 12:45PM |
Re: Has any one built the Micromake printer? January 22, 2016 03:35PM |
