delta level issue August 14, 2015 09:08AM |
Re: delta level issue August 14, 2015 09:45AM |
Re: delta level issue August 14, 2015 10:32AM |
LarsK
You have connected the Z proble wrong or set the settings for the z probe wrong.
Issue the following command:
M119
Now manually with your finger activate the Z probe and while holding that issue M119 again.
Report your findings.
Re: delta level issue August 14, 2015 11:52AM |
Re: delta level issue August 14, 2015 11:59AM |
Re: delta level issue August 14, 2015 12:03PM |
LarsK
Please post your configuration.h
Re: delta level issue August 14, 2015 12:04PM |
Re: delta level issue August 14, 2015 12:12PM |
Re: delta level issue August 14, 2015 12:36PM |
Re: delta level issue August 14, 2015 01:09PM |
Re: delta level issue August 14, 2015 01:18PM |
dipenjungi
these are images of my nozzle to bed position at different towers and at the origin.. i dont know how to get flat nozzle movement
LarsK
Something is wrong mechanically or in the wiring or your z probe was not triggered when going to z0.
Redo the test with your finger triggering you z probe.
Post a photo of your Z probe.
Put a multimeter with continuity test on the end stop and see if that triggers.
Re: delta level issue August 14, 2015 01:35PM |
Re: delta level issue August 14, 2015 04:17PM |
LarsK
Can you get a microswitch like this:
Do you have a soldering iron?
Do you have 2 m small cable that we can use to connect it to the RAMPS?
Do you have some small pin connectors? Like any of these:
Do you have some superglue (Locktite glue)?
If yes to all this then I will instruct you how to make a Z-probe and you will be OK soon.
Re: delta level issue August 14, 2015 05:47PM |
Re: delta level issue August 14, 2015 05:58PM |
LarsK
I don't understand if you have a z probe or not.
Please post a photo of your entire printer and one close up of your current z probe.
Re: delta level issue August 14, 2015 09:32PM |
Re: delta level issue August 15, 2015 04:26AM |
LarsK
Hello, please run the below code and report back the z probe results. Based on those numbers I will be able to tell you what is going on. Please be sure to explain if the Z probe does not seem to probe correctly at all point. That is, if it triggers and moves on without actually ever touching the bed.
G1 x0 y0 z10
G30
G1 x55 F2400
G30
G1 X38.9 Y38.9
G30
G1 X0 Y55
G30
G1 X-38.9 Y38.9
G30
G1 X-55 Y0
G30
G1 X-38.9 Y-38.9
G30
G1 X0 Y-55
G30
G1 X38.9 Y-38.9
G30
Re: delta level issue August 15, 2015 04:35AM |
dipenjungi
HI ONLY I CAN PERFORM AT G1 x0 y0 z10 ONLY BECAUSE AT G1 x55 F2400 MY X TOWER CAN'T PERFORM IT WILL GIVE ME WRONG ORIGIN AND SO ON, AT G1 Z10 MY RESULT IS AS BELOW:
>>> G1 x0 y0 z10
SENDING:G1 X0 Y0 Z10
>>> G30
SENDING:G30
Z-Tower Endstop Offsets
-5.4250 X:0.00 Y:0.00 Z:0.00
-5.1750 -15.5000 Tower Position Adjust
-6.1750 A:0.00 B:0.00 C:0.00
-3.2000 -18.2250 I:0.00 J:0.00 K:0.00
-13.6125 Delta Radius: 129.6300
X-Tower Y-Tower Diag Rod: 245.0000
LarsK
G1 x0 y0 z10
G30
G1 x55 F2400
G30
G1 X38.9 Y38.9
G30
G1 X0 Y55
G30
G1 X-38.9 Y38.9
G30
G1 X-55 Y0
G30
G1 X-38.9 Y-38.9
G30
G1 X0 Y-55
G30
G1 X38.9 Y-38.9
G30
Re: delta level issue August 15, 2015 04:36AM |
Re: delta level issue August 15, 2015 02:16PM |
Re: delta level issue August 15, 2015 03:57PM |
Re: delta level issue August 16, 2015 01:46AM |
Re: delta level issue August 16, 2015 07:46AM |
