Re: Moved to Duet + RepRapFirmware-1.09e-dc42 => got print quality issues August 22, 2015 07:05AM |
Re: Moved to Duet + RepRapFirmware-1.09e-dc42 => got print quality issues August 22, 2015 07:34AM |
dc42
PS - don't enable the Move debug (M111S1P4) or any other debug unless you have the USB port connected to a PC and a program such as Pronterface ready to receive it. The debug code uses blocking I/O to make sure that none of the debug output gets lost, and that may cause the main loop to hang if there is nothing to receive it.
Re: Moved to Duet + RepRapFirmware-1.09e-dc42 => got print quality issues August 22, 2015 12:38PM |
roboprint
If I understand right, printer freezes right after printing smallest (inner) circle before going to do bottom level "infill" between outer and inner circle
shadowphile
Well that explains one problem I had today...
Re: Moved to Duet + RepRapFirmware-1.09e-dc42 => got print quality issues August 22, 2015 12:49PM |
Re: Moved to Duet + RepRapFirmware-1.09e-dc42 => got print quality issues August 22, 2015 01:37PM |
roboprint
Looks like this freeze bug is fixed, first 10 layers is printed without problems, still carefully look at my printer.
Re: Moved to Duet + RepRapFirmware-1.09e-dc42 => got print quality issues August 22, 2015 03:20PM |
Re: Moved to Duet + RepRapFirmware-1.09e-dc42 => got print quality issues August 22, 2015 03:54PM |
Re: Moved to Duet + RepRapFirmware-1.09e-dc42 => got print quality issues August 23, 2015 03:25AM |
roboprint
I don't know who is responsible for this now, as both models sliced with Cura.
Model of cylinder sliced in Slic3r with 0.3 mm layer is printed perfectly.
Re: Moved to Duet + RepRapFirmware-1.09e-dc42 => got print quality issues August 23, 2015 03:42AM |
Re: Moved to Duet + RepRapFirmware-1.09e-dc42 => got print quality issues August 23, 2015 05:17AM |
Re: Moved to Duet + RepRapFirmware-1.09e-dc42 => got print quality issues August 23, 2015 06:13AM |
G1 X8.497 Y-23.298 Z29.599 E806.73345 G1 X9.061 Y-23.086 E806.74347 G1 X9.629 Y-22.854 Z29.600 E806.75367 ;LAYER:293 G0 F6000 X9.629 Y-22.853 ;TYPE:WALL-OUTER G1 F1080 X10.188 Y-22.610 E806.76381 G1 X10.736 Y-22.355 E806.77386 G1 X11.281 Y-22.086 Z29.601 E806.78397
Re: Moved to Duet + RepRapFirmware-1.09e-dc42 => got print quality issues August 23, 2015 06:17AM |
Re: Moved to Duet + RepRapFirmware-1.09e-dc42 => got print quality issues August 23, 2015 08:04AM |
Re: Moved to Duet + RepRapFirmware-1.09e-dc42 => got print quality issues August 23, 2015 08:12AM |
Re: Moved to Duet + RepRapFirmware-1.09e-dc42 => got print quality issues August 23, 2015 08:32AM |
Re: Moved to Duet + RepRapFirmware-1.09e-dc42 => got print quality issues August 23, 2015 09:38AM |
roboprint
David, have you changed anything in moving code in the new firmware since this post, where you fixed freeze?
G1 X8.420 Y-33.627 E76.01848 G1 X9.242 Y-33.410 E76.03262 G1 X9.449 Y-33.351 Z0.600 E76.03620 ;LAYER:3 G0 F6000 X9.234 Y-33.381 ;TYPE:WALL-OUTER G1 F1560 X9.849 Y-33.204 E76.04684 G1 X10.457 Y-33.018 E76.05741 G1 X10.658 Y-32.954 E76.06092
Re: Moved to Duet + RepRapFirmware-1.09e-dc42 => got print quality issues August 23, 2015 09:52AM |
Re: Moved to Duet + RepRapFirmware-1.09e-dc42 => got print quality issues August 23, 2015 01:30PM |
Re: Moved to Duet + RepRapFirmware-1.09e-dc42 => got print quality issues August 23, 2015 04:41PM |
Re: Moved to Duet + RepRapFirmware-1.09e-dc42 => got print quality issues August 24, 2015 02:18AM |
Re: Moved to Duet + RepRapFirmware-1.09e-dc42 => got print quality issues August 24, 2015 03:00AM |
roboprint
I just tried again rose using red plastic - everything is OK. So I think this issue is fixed now.
Both yellow and red PLA plastics are from one manufacturer, purchased at the same time, sealed in the two plastic bags with silica gel bag. Both spools are newly open. Also yellow cone is printed very well, so I thought plastic isn't affect print quality. It seems that I was wrong. I will test yellow pla again later.
Thank you!
Re: Moved to Duet + RepRapFirmware-1.09e-dc42 => got print quality issues August 24, 2015 03:07AM |
