Gaps on single walls
August 20, 2015 04:43AM
I'm pretty happy with my Kossel Mini. My prints generally come out good but I seem to be having trouble with single-walled prints.
There are gaps where the nozzle ends with each layer. The surface finish is not so good either I think I have my extrusion rate dialed-in correctly. It only happens with single walls. What could I be doing wrong?
I'm using 0.4mm nozzle, 0.2mm layers, 0.5 layer width, PLA at 200C, retraction 5mm at 60mm/s, using latest Slic3r
IMG_0002 by Bok, on Flickr
IMG_0003 by Bok, on Flickr
Re: Gaps on single walls
August 21, 2015 10:48AM
Layer width should be a multiple of your nozzle diameter. if your nozzle is .4mm then you should have a .4mm layer width. Try that and see if it works.
My Personal Blog. Build blog.
[engineerd3d.ddns.net]
Modicum V1 sold on e-bay user jaguarking11
August 23, 2015 01:56AM
jaguarking11
I've been following Triffd Hunter's guide regarding extrusion (layer) width. I never had problems with it except with this and I don't think extrusion width has anything to do with my problem.
But I tried your suggestion anyway. I printed the twin cylinder calibration. No dice.
IMG_0006 by Bok, on Flickr
I tried lowering the temperature 5degrees every 5mm up and the surface finish got better at 190~185C and the gap is somewhat reduced but it is still not "watertight".
IMG_0008 by Bok, on Flickr
Edited 1 time(s). Last edit at 08/23/2015 02:05AM by boksbox.
August 23, 2015 02:54AM
Looks to be a layer switch problem, also looks very familiar but it was some time ago and I don't remember the details. What is your retraction length and speed? I assume you are using a Bowden extruder.
August 23, 2015 10:07AM
Yes, I'm using a Bowden extruder - retraction length of 5mm at 60mm/s.
August 23, 2015 10:48AM
A couple of thoughts.
I think retraction is involved - causing a loss of pressurization. Can you try a few things?
- In Slic3r print settings - Extruder 1 - try turning off Retract on Layer Change
- Minimum travel after retraction - change to a larger number like 10 - 15 to test
These will cause less retraction, and if retraction is the cause it should get much better.
Now a couple other things you could try.
- To reduce retraction time Increase the retraction feedrate. There can be a slight blob at the point where movement stops and a retract happens. This is enough to cause pressure loss on the start of the next layer.
- I would suggest reducing the unretract speed, but I don't see that option in Slic3r (I have it in smoothie firmware).
- Add a bit of "Extra length on restart". This will push a bit of extra filament when it unretracts. Try .1mm to .4mm. The filament deforms slightly when fed, and this can make up for that, but also can make up a bit of the loss while retracting.
- Reduce retraction length slightly.
Edited 2 time(s). Last edit at 08/23/2015 11:04AM by Paul Wanamaker.
My printer: Raptosaur - Large Format Delta - [www.paulwanamaker.wordpress.com]
Can you answer questions about Calibration, Printing issues, Mechanics? Write it up and improve the Wiki!
August 24, 2015 05:40AM
Thanks, Paul.
You are right. It's pressure loss and nothing is coming out for the first few tenths of a mm after unretract.
First, I turned off retract on layer change and upped min travel after retration to 10 as you suggested.
The print went without a single retraction and came out perfectly watertight. However...
IMG_0011 by Bok, on Flickr
IMG_0014 by Bok, on Flickr
So a retraction is definitely necessary so I tweaked the other parameters you suggested. The "extra length on restart" was crucial. It would still need some dialing in but so far the print has greatly improved.
IMG_0029 by Bok, on Flickr
IMG_0030 by Bok, on Flickr
August 24, 2015 08:09PM
Glad that helped!
With further testing I find that the Extra Length on Restart helps with two things: slight filament deformation, and ooze. The longer the travel distance then the more Extra length is actually needed to compensate for the ooze.
The blob at the end is caused when the retraction happens while the printhead is stationary. This blob is worse with Bowden extruders because the retraction length is longer, and so has more time for the ooze blob to develop.
I have found a solution for the blob. I am using a standalone gcode visualizer, post-processor, and debugger I've written to develop features I'd like to see in Slic3r, and I have just tested something I call Retract while Coasting. The solution is to begin retracting about 1.3mm from the end of a segment (for my printer), then finish the remaining 50% or so of the retract, and no blob is formed. The extrude amount that is not done is added to the un-retract.
You can read about it in this post on Github.
August 24, 2015 09:20PM
Awesome work you're doing there, Paul. I'm looking forward to seeing those features in Slic3r soon. Thanks again!
