Kossel mini jamming with Bronzefill
Posted by M4vrick
August 22, 2015 03:57AM
Hi all smiling smiley
I'm trying to print with bronzefill sample and I have some issues.
It's mainly jamming.
I have to mention my printer is working perfectly for 8 months now with PLA.
But with the bronzefill It's very difficult to extrude, the most I've done is around 2 minutes before jam.
On the first time it was jamming when loading the filament, I manage to succed loading by raising the hot end temperature.
Even with higher temp (actually 225°C) there is jamming after the first layer.
Do you have any advice ?
Re: Kossel mini jamming with Bronzefill
August 22, 2015 04:00AM
What´s the nozzle size? IIRC it would be best to print those special filaments with 0.5mm nozzle at least.
-Olaf
August 22, 2015 04:26AM
My hot end is an original E3D V6 with 0.4mm nozzle.
August 22, 2015 02:27PM
Check with the maker of the filament for the size of the metal dust. I had similar problems with wood filament, the dust had the same max size as the nozzle = jam
