Kossel XL - Ramps 1.4 to Duet - Kisslicer
Posted by VaderZA
August 22, 2015 03:40PM
Hi All
I am hoping someone has seen this before or can advise. I upgraded my Kossel XL from a Ramps board to a Duet board and running DC42's 109e firmware. My slicer of choice was Kisslicer as I have had good consistent prints in the past. Happy to say new Duet is installed, calibrated and everything is working. My problem is when I load gcode from Kisslicer and the hot end is up to temp the effector runs off and crashes into either the X or Z verticals. Files fom Slic3r on the other hand work fine. I tried different combinations of start up gcode and in fact got one or 2 files from Kisslicer to printed fine. The interesting part is other files with the same start gcode and slicer settings ran off like before. I have shared 2 files on google drive that were both process through Kisslicer with the same settings, the clamp prints perfect but the effector crashes the effector. Link as follows:
[drive.google.com]
I have tried both 5D-Relative E and 5D-Absolute with the same results. I have also included G90 and M83 into start g-code as I have read in other posts.
Thanks in advance!
Re: Kossel XL - Ramps 1.4 to Duet - Kisslicer
August 22, 2015 07:43PM
Hi VaderZA,
Please install the 1.09g firmware release candidate at [dl.dropboxusercontent.com] and try again. If that doesn't help, please provide your config.g file.
- David
August 23, 2015 04:33AM
Morning David
Oh wow that was fast. As soon as I get home I will try it and let you know.
August 23, 2015 07:36AM
Hi David
Wow thanks so much, the effector file now works. I will run a few more files through Kisslicer and report back. Did you find something that was causing the problem? I am obviously really nervous on print starts at the moment with one finger on the power button and one finger on the emergency stop.
Just on a side note the drag and drop file upload now works in this version as well.
August 23, 2015 08:08AM
VaderZA
Hi David
Yes, there was a problem that occasionally caused moves to be aborted. It never occurred to me when doing regular prints, but after another user reported it I found I could sometimes make it happen by doing long XY moves with a small Z component.
August 23, 2015 08:28AM
Awesome, thanks again.
August 23, 2015 11:18AM
Hi David
The good news is other files through Kisslicer are working, however I notice when the head travels down to start the print about mid way down there is an aggressive jerk as the head moves in either the X or Y axis towards the start point of the print. The job prints smoothly, it is only the initial move that concerns me.
August 23, 2015 01:31PM
VaderZA
Hi David
Can you attach the gcode for the star of the print?
August 23, 2015 02:35PM
I found my speed settings in Kisslicer were too high (mm/sec in kisslicer vs mm/minute in gcode). Have change it but am currently busy with a long print. Will try the same file with slower feed rate speeds tomorrow. The macro feature in your firmware is really helpful and the H parameter for G30 is awesome. I must say my printer is much smoother with the duet and your firmware. Thanks for all the hard work.
Sean
August 24, 2015 04:38PM
Hi David
Slower feedrate motion is perfect, no more jerk on initial move.
Thanks again,
Sean
August 24, 2015 04:53PM
Thanks for the feedback!
