Hot end Carriage shifting August 23, 2015 03:27PM |
Re: Hot end Carriage shifting August 23, 2015 04:14PM |
Re: Hot end Carriage shifting August 23, 2015 04:25PM |
mrmuffin
I recently started a project on my kossel mini when I noticed that some of the cylinders I was printing did not come out circular. There was a difference of about 1mm on either side of the cylinder. I decided to print a cube to test this further and found the same thing. One side was 1mm longer than the other. The weird thing was that no matter the size it was always 1mm off. I sat and watched my printer and noticed that the carriage where the hot end is attached wobbled from left to right when the printer moved in the y-axis. My belts are tight and as far as I know the printer is calibrated so that the head moves parallel to the bed. I think there is some sort of backlash happening but im not sure what to tighten or what to check.
Here is my printer
[attachment 60585 20150715_215237.jpg]
[attachment 60587 20150715_215257.jpg]
The hot end tilts like this one only the head is picking up when it shouldn't
[attachment 60588 thisone.jpg]
Re: Hot end Carriage shifting August 23, 2015 04:52PM |
dougal1957
Looking at your photos it appear's that your rods are not parallel ie your effector may be installed rotated by 120 degrees that would cause all sorts of weird effects the rods MUST be parallel for the thing to work correctly.
Doug
Re: Hot end Carriage shifting August 24, 2015 12:05AM |
Re: Hot end Carriage shifting August 24, 2015 12:19AM |
Re: Hot end Carriage shifting August 24, 2015 02:18AM |
Re: Hot end Carriage shifting August 24, 2015 02:35AM |
dc42
dougal1957
Doug
I think you mean 60 degrees, but otherwise I agree.
Re: Hot end Carriage shifting August 24, 2015 02:57AM |
o_lampe
PS: Just found an interesting roller, that would provide axial and radial stability ( the small black one )
Re: Hot end Carriage shifting August 24, 2015 03:16AM |
Re: Hot end Carriage shifting August 24, 2015 03:25AM |
o_lampe
Thanks David,
am I right, these rollers roll on the face of the extrusion? Did you print your own carrier to match the smaller diameter?
I only have standard t-slot extrusions, I´m afraid their v-center section won´t fit there.
-Olaf
