Kossel Mini Missing M666 level gcode
Posted by b3nnb
August 26, 2015 09:38AM
Hey Gang,
I am new to reprap builds and i have finished a Kossel mini with an e3d and wades extruder RAMPs 1.4 and im not sure how to get the Marlin version. It technically prints but very sloppy.
It looks like it is too high from the print surface on 2 sides of the print bed so i have been trying to level it so i can print out some auto level probe parts.
But my printer doesnt have M66 or M665 to adjust the points.
Any ideas how i can can my nozzle manually calibrated?
Edited 1 time(s). Last edit at 08/26/2015 09:39AM by b3nnb.
Re: Kossel Mini Missing M666 level gcode
September 20, 2015 02:27AM
I'm having the same problem as you are. It seems the only way right now is modifying to code directly to change the parameters, but seeing how much time it took in this video, there must be a better solution, or there should be a firmware upgrade which contains those commands for this printer.
September 20, 2015 02:47AM
When using Pronterface (or whatever), when Marlin is reset, the version should be in the initial blast of stuff it outputs at boot, or you can just read it from the source in the copy you used in the IDE to upload it . . .
- Tim
September 20, 2015 03:30AM
Does your Kossel come with adjuster screws on the carriers to tune the endstop height?
If so, use pronterface to follow this calibration guide.
-Olaf
September 20, 2015 07:04PM
Get Rich Cattels marlin. It has m666 and m206
But i find adjustment screws on the carriages invaluable
