External stepper drives with Duet? August 31, 2015 10:53AM |
Re: External stepper drives with Duet? August 31, 2015 11:28AM |
Re: External stepper drives with Duet? August 31, 2015 12:10PM |
Re: External stepper drives with Duet? August 31, 2015 05:02PM |
Re: External stepper drives with Duet? August 31, 2015 05:58PM |
pkm
Thanks, David!
"Soon" meaning a few days or a few weeks/months?
Re: External stepper drives with Duet? September 01, 2015 08:35AM |
Re: External stepper drives with Duet? September 01, 2015 08:38AM |
Re: External stepper drives with Duet? September 01, 2015 09:39AM |
Re: External stepper drives with Duet? September 01, 2015 12:24PM |
pkm
I successfully connected one drive. With 64 or 128 microostepping the motor moves a lot smoother.
What is the maximum step rate for Duet?
Re: External stepper drives with Duet? September 02, 2015 03:02PM |
Re: External stepper drives with Duet? September 02, 2015 03:35PM |
Re: External stepper drives with Duet? September 02, 2015 04:15PM |
Re: External stepper drives with Duet? September 02, 2015 04:22PM |
Re: External stepper drives with Duet? September 02, 2015 04:38PM |
pkm
Not so much, I guess. Just find the corresponding inputs on ramps and connect them to Duet's outputs. I'd probably use a breadboard instead of ramps.
Re: External stepper drives with Duet? September 03, 2015 06:37AM |
Re: External stepper drives with Duet? September 04, 2015 06:59AM |
Re: External stepper drives with Duet? September 04, 2015 07:13AM |
pkm
I'm just thinking that step times might be reduced in 1.09i, and the drives miss step pulses at higher rates?
Re: External stepper drives with Duet? September 04, 2015 07:35AM |
Re: External stepper drives with Duet? September 05, 2015 03:55PM |
Re: External stepper drives with Duet? September 05, 2015 04:28PM |
Re: External stepper drives with Duet? September 05, 2015 06:08PM |
Re: External stepper drives with Duet? September 05, 2015 06:15PM |
Re: External stepper drives with Duet? September 05, 2015 06:25PM |
Re: External stepper drives with Duet? September 06, 2015 03:58AM |
Re: External stepper drives with Duet? September 06, 2015 05:19AM |
Re: External stepper drives with Duet? September 06, 2015 07:26AM |
pkm
Also, as all my prints go wrong yet, I've extensively used pause button. And the web-interface freeses... like each 2nd time when pausing.
Re: External stepper drives with Duet? September 06, 2015 09:20AM |
pkm
Re: External stepper drives with Duet? September 06, 2015 10:38AM |
dc42
If you are getting lots of pauses when printing that model, could it be that you are using direct print over USB and you haven't told the host program not to wait for "OK" after each command?
Re: External stepper drives with Duet? September 06, 2015 10:59AM |
pkm
dc42
Thanks for the fixes!
No, I was printing via web-interface. To tell the truth, I could not get S3D to connect with Duet. Repetier was not willing to connect either, but then I set Reset on connect to "Due native USB port". Sure thing, Pronterface connects out of box.
I find the web-interface pretty convenient, and the micro-USB cable is too short anyways
Re: External stepper drives with Duet? September 06, 2015 11:16AM |
