So i got a delta type printer now. Coming from a prusa i3 (ebay auora z605)
Its a micromake (kossel mini clone) woth heated bed. I do need a better way to clamp the hed down for the most part it good right now.
So i did my frist test print.this is how it turn out
On the left is my delta. On the right is the prusa i3.
Can i get some help with setting this up correct?
All the delta setting for the rods should be correct. I used the default firmware them i took my own readings and there are within +/- 1mm
As you can see the delta 10mm cube isnt square its kinda rounded. Also around 9mm i know i need to adjust the steps to make it bigger.
The first layer and skirt are good. Once it goes from there it starts to get smaller and more rounder. Then top layer is square tho but smaller.
And help anyone could give wouls be great. These delta are very new to me.
Edited 1 time(s). Last edit at 09/03/2015 06:35AM by xile6.
