Kossel 2020 autolevel marlin + repetier
Posted by pazza
September 16, 2015 01:49AM
Hi every one
long time reader 1st time topic writer...
Setup: Kossel 2020 rev b
marlin v1
repetier v 1.5.6
Question . Once ive done the auto level bed calibration...what do i do with the numbers that its spits out..do they need to be put into marlin...
i dont understand what the next step involves
any help greatly appreciated.
Re: Kossel 2020 autolevel marlin + repetier
September 23, 2015 09:40PM
Nothing.
The firmware has whats called a planner. It is a table of adjustment values. It will remember them until you do a g28. So if you home you have to repeat the auto bed level dance. You can setup your before and after gcodes to do both before each print or do neither and instead go to a parking position after a print. If you do not print multiple consecutive prints i would do it at the start of each because forgetting to do it is a false start....
October 05, 2015 07:34AM
I think at the end of run, you have to store the values in EEPROM i think using m500... But EEPROM storage must be enabled inside Marlin sketch..
