just installed duet and no good joy for me September 18, 2015 09:04PM |
Re: just installed duet and no good joy for me September 19, 2015 02:54AM |
thetazzbot
Printer was printing fine with ultimaker arduino combo but I wanted "modern electronics"... So i upgraded to duet and dc42 firmware and spent two solid days trying to get a print. Travles are nice and smooth, endstops correctly set. Motor current set at 650. Belts tight everything normal but the layers are aweful and look like my prusa when it skips and shifts the layers.
Printing 20x20x20 cube the corner where it layer shifts is really bad.
Also uploading large file is hopeless. The upload speed is pathetic. Any suggestions?
Re: just installed duet and no good joy for me September 19, 2015 03:12AM |
Re: just installed duet and no good joy for me September 19, 2015 11:28AM |
Re: just installed duet and no good joy for me September 19, 2015 01:29PM |
Ezrec
If you are getting layer shifts, make sure your end stop cabling is separate from your stepper cabling.
If not, stepper signals can crosstalk onto the endstop wiring, causing false endstop events during the print.
3v duet signaling is much more susceptible to this than 5v arduino signaling.
Re: just installed duet and no good joy for me September 19, 2015 03:54PM |
Re: just installed duet and no good joy for me September 19, 2015 04:41PM |
Ezrec
Thanks for the correction about the Duet signaling - I was not aware of the filer capacitors on the endstop lines, and was going only by my prior experience with 3v electronics and crosstalk.
Yes, with endstops no longer in the picture, blob jams seem most likely.
Re: just installed duet and no good joy for me September 19, 2015 05:52PM |
Re: just installed duet and no good joy for me September 19, 2015 09:44PM |
Re: just installed duet and no good joy for me September 20, 2015 02:36AM |
Re: just installed duet and no good joy for me September 20, 2015 11:04AM |
Re: just installed duet and no good joy for me September 20, 2015 06:59PM |
Re: just installed duet and no good joy for me September 21, 2015 04:07AM |
