So I have had my Rostock Mini quite some time now and its works okay, but now is the first time I would need some precise dimensions for my prints. I have tried to calibrate the machine as best as I can but in the end there seems to be something weird going on as when I print 100mm by 20mm by 5mm part, the 100mm side is correct lenght but the 20mm side is only 18mm and if I change the DELTA_DIAGONAL_ROD accordingly then the 100mm side is 104mm and the 20mm side is correct.
In the end I'm stuck as I have no idea what to change in the Repetier firmware, or even where to start as it works otherwise okay.
