How to Check Towers October 02, 2015 06:19AM |
Re: How to Check Towers October 02, 2015 06:28AM |
Re: How to Check Towers October 02, 2015 08:54AM |
Re: How to Check Towers October 02, 2015 10:41AM |
nebbian
There are two separate things you need to check:
1) Squareness of the towers to the horizontal extrusions
2) Squareness of the towers to the bed
Re: How to Check Towers October 03, 2015 04:09AM |
nebbian
These are two completely separate issues.
To check 1, you need a carpenters square or angle finder, as well as some diagonal cross braces. Put your square on a horizontal extrusion and square up a tower. When it's square then attach your diagonal brace. Then go around the frame, squaring up the towers against the horizontal extrusions. There are six angles to check (two on each tower).
I only needed two braces to fully square my delta up, I think that this is enough to fully square it in every dimension assuming that top and bottom triangles are all perfect 60 degree triangles.
Once you're totally happy with this, it's time to square up your bed to the towers.
This is easy if you have installed a spring underneath each of the three attachment screws. I like to put a dab of loctite on the screw where it goes into the T nut. This means that you can adjust the level of the bed, and then once the loctite has set you can remove the bed, then replace it and you won't need to relevel it.
Mine is so consistent that I don't need to do a Z probe or recalibrate, even after removing and putting back the bed.
Hope this helps.
Re: How to Check Towers October 03, 2015 05:04AM |
Re: How to Check Towers October 03, 2015 02:38PM |
