FirePick Delta is open source. Why nobody built one? October 06, 2015 04:14AM |
Re: FirePick Delta is open source. Why nobody built one? October 07, 2015 04:28AM |
Re: FirePick Delta is open source. Why nobody built one? October 07, 2015 05:21AM |
... my bad:|
Re: FirePick Delta is open source. Why nobody built one? October 07, 2015 05:38AM |
Re: FirePick Delta is open source. Why nobody built one? October 07, 2015 05:56AM |
Re: FirePick Delta is open source. Why nobody built one? October 08, 2015 01:44AM |
realthor
Hi, I am a fan since the begining of the firepick-delta for it's way to avoid linear rods. Now after a few years I've checked back if anyone has built one and can't find anything. I am posting this in delta forum so you,the delta gurus, can tell me your opinion.
Is, as of now, the firepick delta a good option for a delta printer? On their webpage it mentions Marlin for compatible software so it could be built to only take advantage of the 3d printer for now and maybe adapted later for the pick-and-place stuff.
Thanks.
Re: FirePick Delta is open source. Why nobody built one? October 08, 2015 03:08AM |
Re: FirePick Delta is open source. Why nobody built one? October 08, 2015 03:24AM |
o_lampe
The frame's stiffness is very important for this setup.
Four vertical/ parallel extrusions are not the stiffest platform.
If these guys had guts, they´d build the frame like a pyramid...
-Olaf
Re: FirePick Delta is open source. Why nobody built one? October 09, 2015 01:55AM |
Re: FirePick Delta is open source. Why nobody built one? October 09, 2015 02:00AM |
ekaggrat
somebody built a similar machine but said he had a lot of calibration issues.
[hackaday.io]
Re: FirePick Delta is open source. Why nobody built one? October 10, 2015 09:24AM |
Re: FirePick Delta is open source. Why nobody built one? October 28, 2015 05:35PM |
Re: FirePick Delta is open source. Why nobody built one? October 29, 2015 12:28AM |
Re: FirePick Delta is open source. Why nobody built one? October 29, 2015 10:57AM |
Re: FirePick Delta is open source. Why nobody built one? October 29, 2015 01:44PM |
Re: FirePick Delta is open source. Why nobody built one? October 29, 2015 06:26PM |
Re: FirePick Delta is open source. Why nobody built one? October 29, 2015 06:36PM |
ekaggrat
Does the reprapfirmware support delta mechanisms like the firepick delta?
Re: FirePick Delta is open source. Why nobody built one? October 30, 2015 04:14AM |
Re: FirePick Delta is open source. Why nobody built one? October 30, 2015 09:24AM |
Re: FirePick Delta is open source. Why nobody built one? October 31, 2015 04:21AM |
Re: FirePick Delta is open source. Why nobody built one? November 01, 2015 12:18AM |
[hackaday.io]
Re: FirePick Delta is open source. Why nobody built one? November 01, 2015 10:31AM |
TTN
If you make a solid frame, 0.9 degree steppers, a 32 bit controller, and use very carefully measured parts and and accurate assembly, I think you could make it work.
, with that list you can get cheaper with cartesian.|
Re: FirePick Delta is open source. Why nobody built one? November 07, 2015 05:21AM |
at worst corner of an 80x80mm square with z=70mm moved down from zero reference (upper arms horizontal).|
Re: FirePick Delta is open source. Why nobody built one? November 07, 2015 05:31AM |
lutz_dd
@TTN ... any detailed information regarding the 4% deviation along the z-axis would be really interesting especially the strategy to backtrack measured deviations to the root cause.
FYI my frustrating setup ... arms are directly mounted on the stepper motor shaft 0.9deg, 16 microstep, about 40gr weight endeffector just for PnP SMD 0402, all 3 motor motor are mounted on a single printed piece of PLA, 90mm upper arm, 236mm lower arm ... step resolution in the near of 100um ... accuracy error 2500umat worst corner of an 80x80mm square with z=70mm from zero reference (upper arms horizontal)
Re: FirePick Delta is open source. Why nobody built one? November 07, 2015 05:55AM |
Re: FirePick Delta is open source. Why nobody built one? November 07, 2015 06:03AM |
Re: FirePick Delta is open source. Why nobody built one? November 07, 2015 07:46AM |
Re: FirePick Delta is open source. Why nobody built one? November 08, 2015 04:52AM |
Re: FirePick Delta is open source. Why nobody built one? November 08, 2015 04:58AM |
Re: FirePick Delta is open source. Why nobody built one? November 08, 2015 05:08AM |
Mecch
I found some typos in the formulations
1. In the first term of Equation (4), x2*x ==> should be -x2* x, also the first term in Eq. (5), x3*x should be -x3*x
2. The last equation, the coefficient of the z term : 2(a1+a2(b2-y1)......)*z should be 2(a1*b1+a2(b2-y1)....)*z
In the text preceding Eq. (7), "From (4)-(5)", should be " By Eq (4) and Eq (5), we can express x and y in terms of z to reduce the number of variables.." to make it more clear
