Weird M665 H/R issue October 11, 2015 05:39AM |
Re: Weird M665 H/R issue October 11, 2015 06:30AM |
SolderSucker
Hi all! I've got a strange problem with my mini kossel/duet machine when calibrating, and I wondered if anybody else had come across it.
Now to my thinking, I should be able to just drop the hot end using M665 H by 0.05mm and the job should be done, right? However...ANY adjustment of height using M665 results in the hot end moving anything between 5 and 20mm above the bed when the software reading for Z is zero. For example, my z height in the firmware us set to 229.89 - if adjust to 229.95 it zeros 20mm above the bed. It I use 229.90 it's 5mm above the bed...
Thinking this might be a relative move issue, I have flashed the settings and power cycled the printer. This gave the same results.
This has got me completely stumped, so if anybody can tell me what's going on, I would be very grateful!
config.g
; Configuration file for Mini Kossel kit from Think3DPrint3D
; Communication and general
M111 S0 ; Debug off
M550 PMiniKossel ; Machine name and Netbios name (can be anything you like)
M551 Preprap ; Machine password (used for FTP)
M540 P0xBE:0xEF:0xDE:0xAD:0xFE:0xED ; MAC Address
;*** Adjust the IP address and gateway in the following 2 lines to suit your network
M552 P0.0.0.0 ; IP address (0 = use DHCP)
M554 P192.168.1.1 ; Gateway
M553 P255.255.255.0 ; Netmask
M555 P2 ; Set output to look like Marlin
G21 ; Work in millimetres
G90 ; Send absolute coordinates...
M83 ; ...but relative extruder moves
; Axis and motor configuration
M569 P0 S1 ; Drive 0 goes forwards
M569 P1 S1 ; Drive 1 goes forwards
M569 P2 S1 ; Drive 2 goes forwards
M569 P3 S1 ; Drive 3 goes forwards
M569 P4 S1 ; Drive 4 goes forwards
M574 X2 Y2 Z2 S1 ; set endstop configuration (all endstops at high end, active high)
;*** The homed height is deliberately set too high in the following - you will adjust it during calibration
M665 R105.6 L215.0 B85 H240 ; set delta radius, diagonal rod length, printable radius and homed height
M666 X0 Y0 Z0 ; put your endstop adjustments here, or let auto calibration find them
M92 X80 Y80 Z80 ; Set axis steps/mm
M906 X1000 Y1000 Z1000 E500 ; Set motor currents (mA)
M201 X1000 Y1000 Z1000 E1000 ; Accelerations (mm/s^2)
M203 X20000 Y20000 Z20000 E3600 ; Maximum speeds (mm/min)
M566 X1200 Y1200 Z1200 E1200 ; Maximum instant speed changes mm/minute
; Thermistors
;*** If you have a Duet board stickered "4.7K", change R1000 to R4700 to the following M305 commands
M305 P0 T100000 B3950 R1000 H30 L0 ; Put your own H and/or L values here to set the bed thermistor ADC correction
M305 P1 T100000 B3974 R1000 H30 L0 ; Put your own H and/or L values here to set the first nozzle thermistor ADC correction
M305 P2 T100000 B3974 R1000 H30 L0 ; Put your own H and/or L values here to set the second nozzle thermistor ADC correction
M570 S180 ; Hot end may be a little slow to heat up so allow it 180 seconds
; Tool definitions
M563 P0 D0 H1 ; Define tool 0
G10 P0 S0 R0 ; Set tool 0 operating and standby temperatures
;*** If you have a dual-nozzle build, un-comment the next 2 lines
;M563 P1 D1 H2 ; Define tool 1
;G10 P1 S0 R0 ; Set tool 1 operating and standby temperatures
M92 E663:663 ; Set extruder steps per mm
; Z probe and compensation definition
;*** If you have an IR zprobe instead of a switch, change P4 to P1 in the following M558 command
M558 P4 X0 Y0 Z0 ; Z probe is a switch and is not used for homing any axes
G31 X0 Y0 Z4.80 P500 ; Set the zprobe height and threshold (put your own values here)
;*** If you are using axis compensation, put the figures in the following command
M556 S78 X0 Y0 Z0 ; Axis compensation here
M208 S1 Z-0.2 ; set minimum Z
T0 ; select first hot end
Re: Weird M665 H/R issue October 11, 2015 06:37AM |
Re: Weird M665 H/R issue October 11, 2015 06:53AM |
Re: Weird M665 H/R issue October 11, 2015 08:11AM |
Re: Weird M665 H/R issue October 11, 2015 09:27AM |
Re: Weird M665 H/R issue October 11, 2015 11:16AM |
Re: Weird M665 H/R issue October 12, 2015 05:39AM |
Re: Weird M665 H/R issue October 12, 2015 06:10AM |
Re: Weird M665 H/R issue October 12, 2015 08:12AM |
dc42
I am more interested in whether the M666 values changed at any of these steps, in case they got renormalised to average zero.
Re: Weird M665 H/R issue October 12, 2015 10:29AM |
Re: Weird M665 H/R issue October 12, 2015 12:19PM |
