Bigger 3d delta printer size October 20, 2015 09:14PM |
Re: Bigger 3d delta printer size October 21, 2015 12:50AM |
Re: Bigger 3d delta printer size October 21, 2015 03:01AM |
Re: Bigger 3d delta printer size October 21, 2015 05:20AM |
Re: Bigger 3d delta printer size October 21, 2015 05:53AM |
Re: Bigger 3d delta printer size October 21, 2015 11:57AM |
hercek
But you probably will be printing only very slowly anyway because it will be hard to find belts which are not too springy with one belt length of 2 * 1.5 m.
Re: Bigger 3d delta printer size October 21, 2015 01:05PM |
Re: Bigger 3d delta printer size October 21, 2015 01:28PM |
Re: Bigger 3d delta printer size October 21, 2015 01:30PM |
Re: Bigger 3d delta printer size October 21, 2015 01:33PM |
Re: Bigger 3d delta printer size October 21, 2015 01:35PM |
I'm playing with a design which would use steel cables too. In my case, I would like to achieve at least 7g accelerations with about 0.05 mm dynamic precision while being able to go without bowden. Which is rather hard since the extruder stepper on platform makes the moving part much heavier.Quote
simspeed
I considered these issues in the design of my 1500mm vertical riser enclosed delta. I chose not to use belts and instead went with stainless steel syncromesh cables and matching pitch 15 tooth pulleys.
Re: Bigger 3d delta printer size October 21, 2015 01:41PM |
Yes. As well as H-bot.Quote
simspeed
Core XY provides for both XY steppers to be fixed where neither axis carries a stepper in the motion...right?
Well, you need to realize that in one direction you need to move also the two horizontal smooth rods. So that means the acceleration in one direction may be bigger (the direction in which you do not move the smooth rods). Not sure whether any firmware can take this into account though. Because it actually translates to one diagonal acceleration being bigger. I doubt CoreXY/H-bot firmwares take this into account.Quote
simspeed
Therefore the acceleration in both would be the same, would they not?
Re: Bigger 3d delta printer size October 21, 2015 01:43PM |
hercek
Good luck with yours.
Re: Bigger 3d delta printer size October 21, 2015 01:56PM |
Re: Bigger 3d delta printer size October 21, 2015 02:10PM |
Re: Bigger 3d delta printer size October 21, 2015 02:26PM |
Re: Bigger 3d delta printer size October 21, 2015 11:29PM |
dc42
2. Choose the rod length to put the rods at about 60 degrees to the horizontal when the effector is centred, and not less then 20 degrees to the horizontal when the nozzle is at the edge of the print area.
Re: Bigger 3d delta printer size October 21, 2015 11:42PM |
This site is not working??
Re: Bigger 3d delta printer size October 21, 2015 11:46PM |
Re: Bigger 3d delta printer size October 22, 2015 06:42AM |
Re: Bigger 3d delta printer size October 22, 2015 06:45AM |
Re: Bigger 3d delta printer size October 22, 2015 08:12AM |
harsh
Can anyone tell me about using lead screw of 1.5mm pitch for up-down movement instead of belt, does it affect speed much??
Re: Bigger 3d delta printer size October 22, 2015 08:24AM |
Re: Bigger 3d delta printer size October 22, 2015 04:35PM |
Re: Bigger 3d delta printer size October 23, 2015 03:38AM |
Re: Bigger 3d delta printer size October 23, 2015 04:08AM |
Re: Bigger 3d delta printer size October 23, 2015 05:24AM |
Re: Bigger 3d delta printer size October 23, 2015 09:14AM |
Re: Bigger 3d delta printer size October 23, 2015 09:38AM |
dc42
I use GT2 belts that are nearly 2m long on my 1m high delta, and I haven't observed any problems that I can put down to belt springiness. So I am not convinced that you need to avoid using belts. I see that you can get GT2 belt in 9mm width. Why not use that, assuming you can find compatible pulleys? The extra 50% width would reduce the springiness by 1/3.
Re: Bigger 3d delta printer size October 23, 2015 01:47PM |
I actually recommend belts even for delta. They are easy to use, comfortable and fool-proof. I'm just saying one should be picky what kind of belts especially when quick printing on a tall delta is anticipated. And of course, using wider belts is good. My speculations about using steel cable are not for the general user base.Quote
dc42
