Head fan on Duet
October 29, 2015 09:52AM
Hi all,
Perhaps a basic question for you : The head fan have to be always on however when I connect on Web control, the Fan Control is 0% and I have to set it up manually to 100%
How to fix that parameter ?
Re: Head fan on Duet
October 29, 2015 09:56AM
lolocaledo
Hi all,
You should probably wire your fan (hot-end fan?) directly to the 12V supply, the fan control I believe is regarding a layer-cooling fan which can be controlled via the gcode (slicer).
Edited 1 time(s). Last edit at 10/29/2015 09:56AM by Koenig.
October 29, 2015 10:06AM
Hello,
I find M106 S255 in config.g
with this parameter, head fan is on after initializationDuet reset
October 29, 2015 11:06AM
The FAN0 output is for a print cooling fan, not a hot end fan. A hot end fan should be wired permanently to 12V or whatever your power supply voltage is. On the Duet 0.8.5 there are 2 outputs for always-on fans. On the Duet 0.6 you can connect an always-on fan to the motor loom connector using the outer 2 pins of a 3-pin connector, as shown here (see HOTEND FAN)
You can connect a second always-on fan to the two pins immediately above those two.
Edited 1 time(s). Last edit at 10/29/2015 11:07AM by dc42.
October 29, 2015 04:34PM
Can you control the hotend fan to turn on/off at specific temperature like with Marlin? Currently, my fan turns on after my hotend hits 50 degrees, which is nice so that I don't have to listen to it all the time.
October 29, 2015 04:43PM
Kurzaa
Not yet, but I am planning to add this to RepRapFirnware when it is running on the Duet 0.8.5. That version of the board has two controllable fan outputs.
