Re: Talk me out of (or into) a Delta November 05, 2015 08:11PM |
hercek
If you want to print quickly then you also need high acceleration especially if your models will have a lot of holes. And if you need high accelerations then you need a delta. And my suspicion is that it needs to be delta with ball angle joints and not magnetic joints. I do not know whether magnetic joints can handle high accelerations. People did not respond to my questions about this.
Re: Talk me out of (or into) a Delta November 06, 2015 04:40PM |
Re: Talk me out of (or into) a Delta May 01, 2018 05:52AM |
Re: Talk me out of (or into) a Delta May 01, 2018 06:03AM |
Re: Talk me out of (or into) a Delta May 01, 2018 06:23AM |
Re: Talk me out of (or into) a Delta May 01, 2018 12:04PM |
Re: Talk me out of (or into) a Delta May 02, 2018 05:22PM |
Re: Talk me out of (or into) a Delta May 03, 2018 03:31AM |
Is Kossel XL such a bad design that you need to check calibration before every print? What is the reason for constant (re)calibration? Is the frame wobbly? Maybe the outside temperature changes a lot between different printer runs? ...Quote
Archiclem
Edit : With the smart effector You never fail a print because you can probe the bed distance before every print... It make the machine very reliable
Re: Talk me out of (or into) a Delta May 03, 2018 03:42AM |
Re: Talk me out of (or into) a Delta May 03, 2018 04:27AM |
Re: Talk me out of (or into) a Delta May 04, 2018 03:29AM |
hercek
Oh, I'm a fan of auto-probing. I guess I was the first one who introduced it properly for delta machines. What I'm surprised about is an opinion of auto-probing need before every print. Either it is overrated or the average printers suck.
I heard a lot of complains about mechanical endstops too. I had become worried about it and modified my firmware to touch them 5 times when homing and measure the errors. I rarely make changes without measuring first to see whether the changes are needed at all. So I wanted to know whether I need to replace my mechanical endstops with optical or hall sensors.
Results of my mechanical endstop measurements: It is only about 1 in 1000 cases when the difference is 2 microsteps (between the nearest and the furthest touches). I never had a difference of 3 micrometers. One of the 5 end stop touches is off by 1 microstep quite often though. Microstep length is 12.5 µm. My measurements indicate that the microswitch can be precise plenty enough. I would say that the only requirement is that if the microswitch has a lever then one needs to press it at the location between the lever hinge and the microswitch button so that the lever does not increase the error but keeps it the same or decreases it.
Just to give some feedback on "crappy" microswitch talk I hear way too often too.
I agree. A different bed temperature or different hotend temperature has a significant effect. This cannot be ignored.
Re: Talk me out of (or into) a Delta May 04, 2018 06:02AM |
Re: Talk me out of (or into) a Delta May 04, 2018 11:30AM |
hercek
Re: Talk me out of (or into) a Delta May 04, 2018 01:12PM |
Re: Talk me out of (or into) a Delta June 12, 2018 04:17AM |
Re: Talk me out of (or into) a Delta June 12, 2018 05:07AM |
Re: Talk me out of (or into) a Delta June 12, 2018 05:16AM |
Re: Talk me out of (or into) a Delta June 12, 2018 12:21PM |
Re: Talk me out of (or into) a Delta June 12, 2018 02:22PM |
Re: Talk me out of (or into) a Delta June 12, 2018 02:56PM |
Re: Talk me out of (or into) a Delta June 12, 2018 03:15PM |
Re: Talk me out of (or into) a Delta June 14, 2018 03:19PM |
Re: Talk me out of (or into) a Delta June 14, 2018 06:32PM |
Re: Talk me out of (or into) a Delta June 15, 2018 09:47AM |
Re: Talk me out of (or into) a Delta June 15, 2018 05:42PM |
Re: Talk me out of (or into) a Delta June 16, 2018 03:09AM |
Re: Talk me out of (or into) a Delta June 16, 2018 04:36AM |
Re: Talk me out of (or into) a Delta June 16, 2018 05:07AM |
Re: Talk me out of (or into) a Delta June 19, 2018 01:41PM |
Re: Talk me out of (or into) a Delta September 06, 2018 02:40AM |
scndctr
What's more, mine uses linear rails and not wheels, but I don't know if the rails are really significantly better.
