Re: Talk me out of (or into) a Delta September 06, 2018 03:02AM |
Redemptioner
scndctr
What's more, mine uses linear rails and not wheels, but I don't know if the rails are really significantly better.
Generally using linear rails on a delta it does not, assuming you are using polycarb wheels, improve the print quality. This is due to being unable to adjust pre-load on the linear bearings, something that is a critical element to be able to adjust in order to get perfect prints on a delta (fyi if your carriages and/or effector can move down the Z axis under their own weight you don't have appropriate levels of bearing pre-load).
Re: Talk me out of (or into) a Delta September 06, 2018 03:36AM |
dc42
We'll have to disagree about that. It is important that the sliders don't rotate when the belt stops pulling one way and starts pulling the other way. This does not necessarily mean that with the belts disconnected, the carriages don't drop under their own weight.
Re: Talk me out of (or into) a Delta September 11, 2018 06:24AM |
Re: Talk me out of (or into) a Delta September 14, 2018 04:20PM |
Re: Talk me out of (or into) a Delta September 15, 2018 03:06AM |
