When to use - or + with M666
November 02, 2015 01:42AM
Hi all,
To be sure, what are the M666 parameters when I measure X,Y and Z tower :
X -0.35 Y +1.10 Z -0.95
I am tempted to say M666 X0.35 Y-1.10 Z0.95 is it right ?
After reading many posts, it begin to be confused for me :-)
Re: When to use - or + with M666
November 02, 2015 04:18AM
lolocaledo
Hi all,
Depends on which firmware you are using......
November 02, 2015 04:25AM
In RepRapFirmware, a positive M666 parameter will increase the height of that carriage, and hence increase the nozzle height when the effector is near that tower. In Marlin it may be the other way round.
November 02, 2015 05:12AM
In my first patch adding M666 to Marlin, it is the same: negative value will move carriage down nearer to the bed. The positive value was changed to 0 (i.e. ignored) since it is not safe to move carriage nearer to the endstop after you have already hit it. Anyway later patches may have changed this ... and I do not know since I do not use Marlin any more.
Repetier uses positive values as an indication the carriage should be moved down (i.e. it has just the opposite sign compared to Marlin). I do not know what happens when you try to use negative value in Repetier.
November 02, 2015 06:01AM
Hi all,
Ok thank you.
so now, after doing all calibration procedure again from scratch, after G28 and G32, I've the following auto level result :
"21:53:40 UTC+11G32
Calibrated 7 factors using 13 points, deviation before 0.178 after 0.014"
Just only one thing to resolve : all probe points (7) in the center have 1.45 for Z probe threshold however all probe points (6) on the bed periphery (near the max of bed radius) have between 1.35 and 1.70 Z probe threshold.
Can I resolve this with H parameter on each G30 commande in the bed.g file ?
Have a good day
Laurent
November 02, 2015 06:31AM
Hi all,
One question about H parameter in G30 command : do I have to give the real Z probe threshold to H for each point or the delta Z probe with correct Z probe ?
For example : all center Z probe threshold are 1.45. For Z probe threshold at 1.75, H will be 1.75 or 0.30 ?
Thank you for your help
Laurent
November 02, 2015 07:16AM
Yes you can use the H parameter on the G30 commands to adjust the trigger height at individual probe points relative to the norm. The H value gets added to the G31 Z parameter. So in your example, H0.30 would be correct.
November 02, 2015 09:52AM
Hello,
The last thing I have to setup is the scale. What is the parameter to modify to have a correct scale ?
November 02, 2015 10:13AM
lolocaledo
Hello,
If your size is wrong on all axis XYZ then you steps/mm are off, if your size is correct in the z-axis but wrong in the XY-plane then you need to adjust the "L" parameter of the M665 command.
