Rostock Calibration November 05, 2015 11:40AM |
Re: Rostock Calibration November 05, 2015 01:37PM |
Re: Rostock Calibration November 05, 2015 03:27PM |
Re: Rostock Calibration November 05, 2015 04:00PM |
Re: Rostock Calibration November 05, 2015 04:44PM |
Re: Rostock Calibration November 05, 2015 07:45PM |
Re: Rostock Calibration November 06, 2015 01:41AM |
nebbian
Tumbledown, if this only happens while transiting then it's due to the Marlin firmware, and nothing to worry about.
The reason is due to the geometry of a delta printer, and the firmware not calculating every point in space between two points. In some cases when transiting, the firmware just calculates the final point, and drives all the motors at a certain speed to get there. This means that the head can move in an arc to get to the final place.
Re: Rostock Calibration November 06, 2015 03:05AM |
Re: Rostock Calibration November 06, 2015 03:20AM |
Re: Rostock Calibration November 06, 2015 04:21AM |
n8bot
G0 typically commands an uncoordinated move, which will make every carriage move immediately to the desired end position, causing the direct path you mention.
Re: Rostock Calibration November 06, 2015 05:03AM |
Re: Rostock Calibration November 07, 2015 02:37PM |
Re: Rostock Calibration November 07, 2015 06:27PM |
Re: Rostock Calibration November 08, 2015 01:52PM |
Re: Rostock Calibration November 10, 2015 08:17AM |
