Retract length ... November 08, 2015 05:59AM |
Re: Retract length ... November 08, 2015 06:20AM |
Re: Retract length ... November 08, 2015 08:22AM |
Re: Retract length ... November 08, 2015 09:00AM |
Re: Retract length ... November 08, 2015 09:11AM |
Re: Retract length ... November 08, 2015 01:02PM |
Re: Retract length ... November 09, 2015 03:19PM |
Re: Retract length ... November 09, 2015 03:56PM |
Re: Retract length ... November 09, 2015 04:29PM |
n8bot
Be careful with too much retraction, as if your hot-end is not optimal, or has a very short transition between hot and cold, you can cause jams by having too long of a retract. This can be hidden until you print gcode with many retractions in a small timeframe.
I find that there are ways of combating the drawbacks of a bowden setup with slicer settings, like the coast and wipe functions of simplify3d, or the similar options in KISSlicer and other free alternatives.
Re: Retract length ... November 09, 2015 06:42PM |
Re: Retract length ... November 10, 2015 05:47AM |
Re: Retract length ... November 10, 2015 06:09AM |
lolocaledo
n8bot, about coast parameter in S3D, what is the purpose ? I user S3D and I've never used this parameter
Re: Retract length ... November 10, 2015 06:54AM |
Re: Retract length ... November 11, 2015 10:04AM |
n8bot
You are exactly right about the loose points. I'm speaking even after accounting for these effects, there is a spring effect to the bowden system. This is really unavoidable, as the tube needs to be flexible and the diameter of the filament cannot be exactly the same as the bowden tube or it would bind. I'm even running a 1.8mm ID bowden tube, which is quite tight and requires a geared stepper to drive filament through, and oversized filament will not fit in it. I still see the effects of bowden tube springiness. (Hysteresis is the technical term, I think.)
I use retract length of 3.1mm, 60mm/s and a coast value of 0.8mm in s3d. This works well for ABS, after accounting for the things you mention and having the smaller ID tube.
Re: Retract length ... November 11, 2015 11:06PM |
Re: Retract length ... January 10, 2018 07:40AM |
Re: Retract length ... May 22, 2018 05:24AM |
I believe what he was saying (I did this on my Chinese e3d-v6 clone) is that if you look at your hotend and unscrew the push to fit connector then measure everything you will see the push to fit does not go all the way down to the 2mm hole the filament will go in. What the slug is doing is filling in that gap so the connector is now snug against the hole and the filament has no choice but to follow the path.Quote
nipid
Would you mind explaining what do you mean by :
* Hotend side: "This can be eliminated by fabricating a slug that fills in the space with a 2mm hole in it. "
and
* Extruder side: "I got around that by designing my extruder with a built in slug and very little clearence between gear/bearing and feed position. "
