What is the state of the art printer as of 2015 November 15, 2015 05:28AM |
Re: What is the state of the art printer as of 2015 November 15, 2015 05:47AM |
Re: What is the state of the art printer as of 2015 November 15, 2015 06:02AM |
dc42
IMO there isn't much wrong with the Kossel design. You might like to check out my blog entries (see link in my signature) about the Kossel variant I built with 300mm build diameter, metal corners, fast bed heater, touch screen control panel, web interface, and fast auto calibration. One change I am currently making is to use Igus joints instead of Traxxas. The magnetic joints sound like a good option too and I hope to try them later.
Re: What is the state of the art printer as of 2015 November 15, 2015 09:18AM |
GR4EME
dc42
I was looking at the igus joints for the large printer I'm planning on building and as they are local to me in Northampton lol they seem to have a lot of different joints
Whereas the Traxxas joints take an M3 screw through the ball and an M4 screw in the tail, the Igus joints take the same size of screw in both. In order to be compatible with the existing Robotdigg metal carriages and effector, M3 screws must be used. The tail of the Igus joint could be connected directly to 5mm o.d. x 3mm i.d tube, but I felt that the existing 6mm tube was already a little on the small size for the arm length. So I used 7mm x 5mm tube, with pieces of 5mm x 3mm acting as converters at the end.
Re: What is the state of the art printer as of 2015 November 15, 2015 09:43AM |
Re: What is the state of the art printer as of 2015 November 15, 2015 03:53PM |
GR4EME
Excellent i was thinking of going up in size due to the length of arms, I'm thinking they will be around 625mm long although if i use two tubes one inside the other i can increase the wall thickness of the arm and reduce the flex.
Re: What is the state of the art printer as of 2015 November 15, 2015 04:10PM |
Re: What is the state of the art printer as of 2015 November 15, 2015 04:29PM |
Re: What is the state of the art printer as of 2015 November 16, 2015 10:11PM |
dc42
Re: What is the state of the art printer as of 2015 November 17, 2015 04:41AM |
Qdeathstar
dc42
bom would be nice, couldn't find on your site...
