Delta printer; Repetier; CuraEngine: holey inner structure November 15, 2015 03:03PM |
Re: Delta printer; Repetier; CuraEngine: holey inner structure November 15, 2015 03:26PM |
Re: Delta printer; Repetier; CuraEngine: holey inner structure November 15, 2015 03:34PM |
Re: Delta printer; Repetier; CuraEngine: holey inner structure November 15, 2015 04:34PM |
Re: Delta printer; Repetier; CuraEngine: holey inner structure November 15, 2015 04:51PM |
xile6
Last time i have holes. The nozzle was clog.
The outer walls printed correct, but infill was very stringing.
I heated the hotend to 240c and then uses a nozzle cleaner. (Very thin piece of metal)
And just ram it in and out a few times.
Then extruded about 10mm.
After that i reprinted the same part without problem
Re: Delta printer; Repetier; CuraEngine: holey inner structure November 15, 2015 07:24PM |
Re: Delta printer; Repetier; CuraEngine: holey inner structure November 16, 2015 04:55AM |
Anonymous User
Re: Delta printer; Repetier; CuraEngine: holey inner structure November 16, 2015 09:15AM |
BigMan200
attached a picture of my 3D print. As you can see, the inner structure has many holes. I am wondering, where I have now to adjust which paremter? Indeed, my first guess was to increas the filament flow, but as far as I have seen, I can only adjust the filament flow for the whole print-out
Firmware: Repetier 0.91
Slicer: CuraEngine
Printer: Delta-type
I would be very grateful for any tips!
Re: Delta printer; Repetier; CuraEngine: holey inner structure November 16, 2015 01:02PM |
Re: Delta printer; Repetier; CuraEngine: holey inner structure November 16, 2015 01:07PM |
Paul Wanamaker
Unfortunately Cura does not appear to allow you to set your extrusion width independently for different types of extrusion like Slic3r does for perimeters, infill, support.
I do have some ideas, but I need more information. Can you please attach the Gcode file?
Until then please take a magnifying glass and look at the infill:
1) Is it printing every infill line every layer, or is it printing one direction one layer, and the other direction on the next layer? You should be able to see this when it's printing too.
2 Look closely at the breaks. Is there curled up filament just before or after the gaps?
3) Are there also skips in the outside wall?
Re: Delta printer; Repetier; CuraEngine: holey inner structure November 16, 2015 01:43PM |
Re: Delta printer; Repetier; CuraEngine: holey inner structure November 16, 2015 02:31PM |
BigMan200
However when I build my Delta-Printer (own design) I had one think in mind: speed. So I think, next I will increase all speed values together step-by-step. In the moment I am getting the breaks, will try to maintain this higher speed by increase the filament flow.
Re: Delta printer; Repetier; CuraEngine: holey inner structure November 16, 2015 08:10PM |
Hercek
If you have a bowden extruder then try to maintain all speeds about the same. They can differ but not much.
The problem is the time delay and elasticity in the bowden. Higher speeds need more pressure but slicers do not factor this in. They tried to factor this in in the firmware (which I think is a wrong place to do it). The firmware feature name is advance. But it takes into account only the elasticity and not the time delay. The time delay may or may not be predictable due its cause being friction in bowden. And the time delay compensation is hard to do only in firmware. The result is that the firmware "advance" feature does not work well.
Re: Delta printer; Repetier; CuraEngine: holey inner structure November 17, 2015 01:04PM |
Re: Delta printer; Repetier; CuraEngine: holey inner structure November 17, 2015 02:14PM |
Thanks, this is something I have been pondering, since I new it wouldn't be linear, but I hadn't researched it. (I was going to try to determine some of that experimentally, when testing going from high to low pressure). See attached screenshot.Quote
Hereck
Flow should depend linearly on square root of pressure since the reynold's number is low.
Hereck
There will be:
constant component from simple play in the bowden quick couplings
linear component from simple elasticity of both bowden and filament
and this will be time delayed because the filament movement will be slowed down in the bowden by friction forces
Yes, that's how it works. I arbitrarily set the length of the acceleration segment (see screenshot). It inserts acceleration before the first segment, and continues through segments till it needs to break a segment, and then sets normal acceleration. This length could be set by formula at a later date, to make things less complex for the user.Quote
Hereck
Note: Of course, the first segment acceleration may spill to more segments if the first segment is too short.
Re: Delta printer; Repetier; CuraEngine: holey inner structure November 17, 2015 03:46PM |
Re: Delta printer; Repetier; CuraEngine: holey inner structure November 18, 2015 03:51AM |
Hereck
Preassure will depend linearly on force at the hotend
Re: Delta printer; Repetier; CuraEngine: holey inner structure November 18, 2015 06:26PM |
Re: Delta printer; Repetier; CuraEngine: holey inner structure November 18, 2015 09:18PM |
-/\/\/\/-##-/\/\/\/-##-/\/\/\/-##-/\/\/\/-##-/\/\/\/-##-/\/\/\/-Modelling the spring part is easy (Hooke's law): f = k₂ * x
Re: Delta printer; Repetier; CuraEngine: holey inner structure November 19, 2015 12:32AM |
I agree. Very fortunately Slic3r has a Verbose Gcode output mode, so I can identify each kind of segment, with some limits - I may not know if infill is sparse or solid. If it starts at the right pressure I'm betting it will be fine tho.Quote
Hercek
..the "back-pressure" effects will be predictable (no random process here like it is there with the friction in bowden). The "back-pressure" should be covered by the k constant. The only problem is that the constant will be different for a bridge (empty space below nozzle) and a normal layer (solid plastics after a small air gap). This is one of the reasons why a good pressure management cannot be done efficiently in the firmware. The firmware does not know whether the current path segment is a bridge or not.
Very difficult indeed.Quote
Hercek
The hard part is how to compensate for the filament friction in the bowden. The problem with friction is that it is a random process. If you have a brick on a table and start to push it then it is not predictable at which force it will actually start to move. But this random process will have a mean and some variance. If the variance is small enough then we can just use the mean value and we will get good enough results.
This I intend to find out. Having the right basic equation for pressure vs flow is a big help, thank you. If friction is close to linear with pressure, then perhaps increasing ELPu might be enough?Quote
Hercek
Clearly simple model without bowden friction does not work. Otherwise Repetier firmware would already have working pressure compensation.
Re: Delta printer; Repetier; CuraEngine: holey inner structure November 19, 2015 02:01PM |
Re: Delta printer; Repetier; CuraEngine: holey inner structure November 19, 2015 02:40PM |
hercek
... Flow should depend linearly on square root of pressure since the reynold's number is low.
Re: Delta printer; Repetier; CuraEngine: holey inner structure November 19, 2015 03:08PM |
Re: Delta printer; Repetier; CuraEngine: holey inner structure November 19, 2015 04:19PM |
Re: Delta printer; Repetier; CuraEngine: holey inner structure November 19, 2015 06:10PM |
Re: Delta printer; Repetier; CuraEngine: holey inner structure November 19, 2015 07:42PM |
Re: Delta printer; Repetier; CuraEngine: holey inner structure November 19, 2015 08:47PM |
dc42
FWIW both RepRapFirmware and Sailfish implement a pressure advance algorithm that assumes pressure is proportional to extrusion rate and the filament in the Bowden tube compresses in an elastic manner. One of the interesting consequences is that at the end of an extruding move that decelerates to zero speed, you may actually need to retract filament. This in turn means you need to reduce your slicer retraction amount to avoid over retraction.
Re: Delta printer; Repetier; CuraEngine: holey inner structure November 20, 2015 11:36AM |
Re: Delta printer; Repetier; CuraEngine: holey inner structure April 02, 2016 04:07PM |
Re: Delta printer; Repetier; CuraEngine: holey inner structure April 03, 2016 11:36PM |
