The first beta machine based on DC42's Kossel XL
Posted by MightyMouth
December 03, 2015 05:15PM
On DC42's recommendation I contacted Think3dPrint3d about their new Large Kossel and I have just recieved the first beta machine. I cannot wait to get started building but I am going to leave it until the weekend so I can concentrate on it properly. I opted for the black aluminium corners and black extrusions with black printed parts. I did want Yellow printed parts but it wasn't an option on the beta machines, I'll print them myself later. More pics to follow during the build.
Edited 1 time(s). Last edit at 12/03/2015 05:57PM by MightyMouth.
Re: The first beta machine based on DC42's Kossel XL
December 03, 2015 09:03PM
Comes with a ratcheting crimper: best kit ever so far.
December 04, 2015 04:32AM
In the interest of transparency, I paid extra for the crimper.
December 04, 2015 05:10AM
T3P3's kits normally come with all cables pre-crimped. If they said you need a crimper, then I guess for the beta they may not have worked out the correct lengths for all the cables yet.
Edited 2 time(s). Last edit at 12/04/2015 05:12AM by dc42.
December 04, 2015 05:33AM
Yes I suppose I should have mentioned that, the cables in the beta are pre-crimped on one end but have to be cut to length on the other end then the cutoff length reported back.
December 06, 2015 10:42AM
Progress so far
December 06, 2015 11:50AM
MightyMouth
Progress so far
Looking good
Doug
December 06, 2015 12:38PM
Hi there - looks great!
What was the price for the beta kit and how much did you pay extra for the metal corners? I would love to see some more pictures smiling smiley
December 06, 2015 01:31PM
The kit beta kit was the same price as their Kossel Mini £495, I paid £18 extra for black extrusions and £50.40 extra for the Metal Corners.
December 11, 2015 05:03PM
Ok so I have pretty much completed my build, I am kind of scared to power it up for fear of frying something. I have double checked all the connections but I am still hesitant.
December 11, 2015 05:23PM
Good progress! A few suggestions:
- Double check that you have the + and - leads from the PSU connected to the Duet power input terminals the right way round.
- Make sure the stepper motor connections are good. An intermittent connection could damage the driver.
- If it uses an AC mains heated bed like mine, check all the mains connections and grounding of the frame. Use a multimeter to check the grounding, and to check for near infinite resistance between live and ground. Preferably use an RCD adapter to feed mains to the printer.
- There should also be continuity between mains ground and the -ve output terminal of the PSU.
- Set the stepper motor currents in the M906 command to a low value initially e.g. 500 mA until the printer is at least homing correctly.
- Don't apply mains power until you are getting good readings from the thermistors, IR probe and endstop switches with just USB power supplied.
Some of this may already be in the build instructions.
December 11, 2015 07:38PM
Thanks for the tips, I will be sure to do all of those things before I power it on.
December 12, 2015 05:00AM
Lol, I just installed a Azteeg X5 mini and had the same feelings. There is something crazy either in the board design or smoothieware. My power supply is a development unit I got from my job, with knobs to adjust volts and amps, and amps were turned way down. WHen I set the hot end temp the speaker/buzzer started making a scary hissing noise that sounded like something shorted !! With the supply amperage set correctly it made no sound. I'm sure of the cause, but what was going on I have no clue. I'm making a seperate post about the board.
December 12, 2015 11:12AM
OK So my printer is now powered on and I can access the web interface. I have homed the axes successfully and have been reading DC42's blog post Upgrading the Mini Kossel to Duet Electronics Part 4: the Z probe but am confused what M558 parameter I should be using. My kit comes with David's IR Probe so do I use P1 or P2? My config is currently set to M558 P1 X0 Y0 Z0 which was configure by t3p3 as default I suppose but it seems to me it should possibly be M558 P2 X0 Y0 Z0.
December 12, 2015 11:32AM
MightyMouth
this is my M558 line and it works (Have now got 3 of these working)
M558 P1 X0 Y0 Z0 H5 F300 T10000
So P1 is correct
HTH
Doug
December 12, 2015 11:39AM
M558 with P1 is correct. P2 is for a dumb but modulated sensor, where the modulation signal is generated by the Duet. My IR sensor has an on-board microcontroller that generates the modulation.
December 12, 2015 01:57PM
Thanks DC42, I worked it out in the end, I just confused myself reading modulated and un-modulated.
I am at 1605.4 Check Z-probe offsets at 4 points in the Mini documentation because the docs for the XL (or Maxi as it is to be called) aren't complete yet but I don't have the macros listed there. I have
E motors off
Origin
X-tower
Y-tower
Z-10u
Z-tower
Z+10u
Where do I get the correct macros or how do I use these if the procedure has changed?
December 12, 2015 02:51PM
I suggest you don't bother with the macros, because if you have the IR sensor working well then you can auto calibrate. Here's how:
1. Check that the Z probe is working by moving the head to about 5mm above bed centre and executing G30. It should stop at the trigger height.
2. In config.g make sure you have the following parameters:
M665 L parameter - accurately set to your diagonal rod length, measured between bearing centres (mine is 349.5, I don't know what T3P3 uses on that kit)
M665 R parameter - set to your approximate delta radius (mine is about 172)
M665 H parameter - set to the approximate height of the nozzle above the bed when the carriages are all activating the homing switches (mine is about 493)
G31 Z parameter - measure the IR sensor trigger height (between nozzle and bed) at bed centre and use that
M558 H parameter - temporarily set to a higher value than the default 5mm, e.g. 25 (this is the height form which probing starts)
M558 T parameter - temporarily set to a lower value than the default, e.g. 500 (this is the travel speed between probe points)
3. Use [escher3d.com] to generate your bed.g file and put it in /sys/bed.g (or perhaps t3p3 has done this already). I suggest 6 factor and 10 or 13 points.
4. Run G32 to execute auto calibration. Look at the Console page of the web interface to see what the deviation is. Repeat a few times until the deviation stabilises.
5. Run M665 and M666 without parameters, and copy the reported values back into the M665 and M666 commands in config.g. Remove the M558 T and H parameters, or set them to more sensible values to speed up bed probing in future. Upload the new config.g.
6. Reboot and run G32 again, check that everything is OK.
The final G32 should be done with the hot end end bed at printing temperature.
Edited 1 time(s). Last edit at 12/12/2015 04:28PM by dc42.
December 12, 2015 03:55PM
Ah great thanks, I thought you had to do the macros to get close before using the auto calibration.
December 12, 2015 04:29PM
MightyMouth
The trick is to increase the M558 H parameter so that it probes from a great height, to avoid the risk of crashing into the bed before probing or while transiting between probe points. However, if you see it probing with the IR sensor not over the bed, then stop and change things, e.g. reduce the probing radius.
Edited 1 time(s). Last edit at 12/12/2015 04:30PM by dc42.
December 12, 2015 05:37PM
OK so I don't have an H or T parameter beside M558, I assume I just add them to override defaults?
Mine looks like
M558 P1 X0 Y0 Z0
Should I make it look like
M558 P1 X0 Y0 Z0 H25 T500
Also where you say "G31 Z parameter - measure the IR sensor trigger height (between nozzle and bed) at bed centre and use that" is that with or without the copy paper in place?
Edited 1 time(s). Last edit at 12/12/2015 05:54PM by MightyMouth.
December 12, 2015 06:03PM
MightyMouth
Mine looks like
M558 P1 X0 Y0 Z0
Yes.
MightyMouth
One way to measure trigger height:
1. Jog the nozzle down until it is just touching the bed or just gripping a sheet of paper (whatever your preferred method of setting Z=0 is).
2. Send G92 Z0
3. Send G1 Z5 F1000 and remove the paper.
4. Send G30 S-1 and then read off the trigger heigh from the web interface or by sending M114,
In theory the paper is 0.1mm thick. In practice there is some elasticity in the print head, so when it is gripping the paper more than slightly, you can take that position as Z=0.
Edited 1 time(s). Last edit at 12/12/2015 06:03PM by dc42.
December 12, 2015 06:11PM
ok thanks, so using that method I am getting 0.95 as the trigger height which is the same as if I move the head down .05 increments until the led comes on.
Edited 1 time(s). Last edit at 12/12/2015 07:00PM by MightyMouth.
December 12, 2015 06:59PM
ok so after 4 runs it settled down so I ran M665 and M666 which came back
Diagonal 350.00, delta radius 178.05, homed height 495.90, bed radius 140.0, X 0.15°, Y 0.12°, Z 0.00°
Endstop adjustments X-0.28 Y0.44 Z-0.17
I don't know what to do with the X 0.15°, Y 0.12°, Z 0.00° after the bed radius.
Also these are the numbers when cold, should I use these or the numbers after the hot run.
Edited 1 time(s). Last edit at 12/12/2015 07:11PM by MightyMouth.
December 13, 2015 03:30AM
MightyMouth
The XYZ numbers after the bed radius should be added to the M665 command i.e. X0.15 Y0.12 Z0
I do a single autocalibration before I print but after heating the bed and hot end to operating temperature. Then it doesn't matter whether I have hot or cold values in config.g, or what temperatures I am using.
December 13, 2015 06:51AM
Thanks again, all seems to be working fine. I don't suppose you could post your slic3r ini file?
December 13, 2015 07:04AM
This is great... following topic.
December 13, 2015 07:09AM
Thanks. There seems to be quite a lot of noise from something while moving and some resonance from something, possibly the belts. I am ready to print something but I don't really no how to configure slicer and no config file was supplied with the beta kit.
Video of the printer calibrating.
December 13, 2015 12:54PM
Sadly I had to give up using slic3r because it crashes almost every time I try to slice anything with it. I now use S3D instead. Here is a summary of the settings I use for PLA:
Bed: 70C (it is quite a lot cooler than that on top of the glass)
Hot end: 200 or 205C first layer, 195C remaining layers
Layer height: 0.2mm
Speed: perimeters 50mm/sec, infill 100mm/sec, small perimeters 10mm/sec, travel 200mm/sec, first layer speed 50%, external perimeters 80%.
Retraction: this is critical. To little and you will get a small blob at the start of each travel move. Too much and the E3D hot end will jam. So increase it until the blobs disappear. My printer has a 660mm Bowden tube and needs 8mm retraction. I use retraction speed 100mm/sec and lift Z 0.5mm.
December 13, 2015 01:54PM
I have set up slicer this way but have noticed that my hotend isnt being turned on by the gcode though the bed is.
