Concept: Large format Delta/Cartisian printer December 04, 2015 05:41PM |
Re: Concept: Large format Delta/Cartisian printer December 04, 2015 06:53PM |
Re: Concept: Large format Delta/Cartisian printer December 04, 2015 07:07PM |
n8bot
Interesting. The main problem is that there is no software to control this.
Also, what would be the advantage for the added complexity?
Re: Concept: Large format Delta/Cartisian printer December 04, 2015 07:23PM |
MrMeeeseeeks
n8bot
The software would be a challenge. It would be interesting peice of code.
As for Advantages? Speed is the main idea. You could have the base plate move the left as the delta moves to the right, that kind of concept. I haven't worked it out though so I'm only assuming it would increase in speed. Another advantage would be an extra 300mm XY demension.
Re: Concept: Large format Delta/Cartisian printer December 04, 2015 07:34PM |
n8bot
MrMeeeseeeks
n8bot
I'm not sure I understand how a greater build volume would be achieved? The gantry/frame of the cartesian would certainly be the limiting factor, and the delta could just vary its position within it.
Re: Concept: Large format Delta/Cartisian printer December 05, 2015 04:35AM |
Re: Concept: Large format Delta/Cartisian printer December 05, 2015 11:09AM |
o_lampe
I can't see the picture. The link is broken.
I guess you want to print on a moving bed instead of a fixed one. Of course this would increase build volume. ( if you keep the bed moving only in x-direction you can print "endless")
Print speed won't increase much as your extruder might be the limiting factor.
I had a similar idea for "mass production", where the bed is more like a giant washer/donut with its center on the z-axis.
It would rotate 30- 60° further after a print is done, so I'd be able to print multiple parts over night.
-Olaf
Re: Concept: Large format Delta/Cartisian printer December 05, 2015 12:00PM |
Re: Concept: Large format Delta/Cartisian printer December 05, 2015 06:05PM |
Re: Concept: Large format Delta/Cartisian printer December 06, 2015 05:36AM |
