HELP: Auto Level moves in wrong direction
Posted by lalalandrus
December 05, 2015 01:41AM
I have a RAMPS 1.4 running marlin 1.1-RC. The printer works in every way except that when I auto level, the printer wants to move in the "z" direction everytime. I have tried doing what was suggested in this thread as well as clearing the EEPROM and I seem to have no effect no matter what parameters I change in the configuration file.
[forums.reprap.org]
Any help is appreciated, thanks in advance.
Attached is the config file.
open | download - Configuration.h (47 KB)
Re: HELP: Auto Level moves in wrong direction
December 05, 2015 01:46AM
I think it will Home first before starting autocalibration...
December 05, 2015 02:13AM
no it just crashes into the end stops (belts start slipping), really hope i can fix this before i destroy my printer smiling smiley
Edited 1 time(s). Last edit at 12/05/2015 02:13AM by lalalandrus.
December 05, 2015 08:14AM
lalalandrus
Does g28 home by moving up hitting tge endstops and then moving down a mm or 2?
Does gcode. G1 Z80 F6000
Move the printer down a little more then half way?
If do then the motors are setup correct. Next i would check the endstop while homed.
Should read
X, y ,z max triggered
While Z min open.
December 05, 2015 11:12PM
yea i started doing that and i kept doing m119 to see the switch states and was seeing the right ones were open and ignoring the missing switches....
...until i saw this
[github.com]
which means they all should have been open. i was ignoring the MIN_STOPS when i should not have. assumptions are not good!
thanks for the help guys!
Edited 1 time(s). Last edit at 12/05/2015 11:13PM by lalalandrus.
