How would I edit Marlin so Auto Level (G29) probes areas twice? December 05, 2015 03:57PM |
Re: How would I edit Marlin so Auto Level (G29) probes areas twice? December 05, 2015 05:34PM |
Re: How would I edit Marlin so Auto Level (G29) probes areas twice? December 06, 2015 06:15AM |
G1 F4000 X-124.8 Y-72 Z20 g30 g0 z20 g30 g0 z20 g30 g0 x0 y0 z100
Re: How would I edit Marlin so Auto Level (G29) probes areas twice? December 06, 2015 07:22AM |
Re: How would I edit Marlin so Auto Level (G29) probes areas twice? December 06, 2015 12:48PM |
hercek
If you do not understand C at least a bit then this post is not for you.
Here is a patch which probes each point 5 times and uses results only from the middle 3 probes (ignoring the first and the last one).
[github.com]
It would be better to ignore probes with the biggest and the smallest deviation but I did not bother in Marlin. I have that in Repetier though. You can modify the Marlin patch the same way.
Re: How would I edit Marlin so Auto Level (G29) probes areas twice? December 06, 2015 02:42PM |
