Online least-squares delta printer calibration calculator December 06, 2015 08:08AM |
Re: Online least-squares delta printer calibration calculator December 06, 2015 11:48AM |
dc42
I have provided a delta printer calibration wizard at [escher3d.com]. This uses the same least-squares algorithm that I implemented in RepRapFirmware. Instructions for using it are at the top of the page.
If you try it, please let me know how well it works (or doesn't work) for you, and which printer firmware you use. In particular, I am not sure that the sign of the M666 endstop corrections is correct for all firmwares.
dc42
Also available is a wizard for generating a bed.g file for RepRapFirmware, at [escher3d.com].
Re: Online least-squares delta printer calibration calculator December 06, 2015 01:17PM |
Re: Online least-squares delta printer calibration calculator December 08, 2015 03:39PM |
Re: Online least-squares delta printer calibration calculator December 08, 2015 04:03PM |
Re: Online least-squares delta printer calibration calculator December 08, 2015 05:02PM |
Re: Online least-squares delta printer calibration calculator January 01, 2016 03:19PM |
Re: Online least-squares delta printer calibration calculator February 14, 2016 11:26AM |
Re: Online least-squares delta printer calibration calculator February 14, 2016 05:00PM |
Re: Online least-squares delta printer calibration calculator September 09, 2016 10:02AM |
Re: Online least-squares delta printer calibration calculator September 13, 2016 06:15AM |
Re: Online least-squares delta printer calibration calculator September 13, 2016 12:01PM |
Re: Online least-squares delta printer calibration calculator September 14, 2016 01:00PM |
Re: Online least-squares delta printer calibration calculator September 15, 2016 03:08AM |
Re: Online least-squares delta printer calibration calculator September 15, 2016 03:09PM |
Re: Online least-squares delta printer calibration calculator September 16, 2016 10:20AM |
Re: Online least-squares delta printer calibration calculator September 16, 2016 10:43AM |
Re: Online least-squares delta printer calibration calculator September 16, 2016 10:52AM |
shofman
Ok I will do this.
Do you have a checklist of the typical geometrical errors in a delta build ?
Re: Online least-squares delta printer calibration calculator September 16, 2016 10:58AM |
Re: Online least-squares delta printer calibration calculator September 16, 2016 12:38PM |
shofman
Is it important that the hotend is perpendicular with the effector ? I think I have a problem with this (play between them ).
Re: Online least-squares delta printer calibration calculator October 16, 2016 01:23PM |
Re: Online least-squares delta printer calibration calculator October 16, 2016 05:58PM |
Re: Online least-squares delta printer calibration calculator October 17, 2016 01:17AM |
Re: Online least-squares delta printer calibration calculator October 17, 2016 02:39AM |
Re: Online least-squares delta printer calibration calculator October 17, 2016 03:19AM |
Re: Online least-squares delta printer calibration calculator October 17, 2016 07:53AM |
Re: Online least-squares delta printer calibration calculator October 17, 2016 03:38PM |
Re: Online least-squares delta printer calibration calculator October 18, 2016 03:24AM |
Re: Online least-squares delta printer calibration calculator October 18, 2016 04:55PM |
roboprint
David, do you have the opportunity to add simple M665 and M666 command parameters parser to fill initial parameters of calculator? Just field (like commands field at the end of calculator) where user can enter M665 and M666 commands from his config to fill initial values.
Also simple list of G1 commands to move effector close to each probe point would be useful too. The user will be able to copy command directly to console to move effector to next probe point.
Re: Online least-squares delta printer calibration calculator November 05, 2017 11:33AM |
