Delta pulley and idler dimensions question December 06, 2015 05:58PM |
Re: Delta pulley and idler dimensions question December 06, 2015 06:31PM |
Re: Delta pulley and idler dimensions question December 07, 2015 02:41AM |
dc42
My delta has the toothed side of the pulley running on Robotdigg smooth idler pulleys that are supported by bearings. But I am not happy with this solution. The teeth make a noise as they run on the pulleys at high speeds. This is sure to be causing belt vibration and loss of precision too.
So I want to switch to either toothed pulleys, or put a twist in the belt and run the back of the belt on the idler. Unfortunately the carriages are too narrow to accommodate a slot wide enough for the twist in the return belt. However, I currently use 4mm standoffs to widen the rod separation, so I can solve this by using printed wider carriages instead of the Robotdigg metal ones.
Re: Delta pulley and idler dimensions question December 07, 2015 02:58AM |
Re: Delta pulley and idler dimensions question December 07, 2015 07:32AM |
Re: Delta pulley and idler dimensions question December 07, 2015 08:45AM |
o_lampe
So I made some dummy 10 x 5 x 4 bearings from PLA and printed my own 22 tooth idler with real MF105 BBs.
It's a pretty close fit in the corners, next time I use 8x5x4 bearings and print smaller idlers.
-Olaf
Re: Delta pulley and idler dimensions question December 07, 2015 02:45PM |
Re: Delta pulley and idler dimensions question December 07, 2015 07:46PM |
Re: Delta pulley and idler dimensions question December 07, 2015 08:40PM |
Re: Delta pulley and idler dimensions question December 07, 2015 08:50PM |
etfrench
Shoulder bolts were designed for applications like this. It isn't good practice to allow bearings to flop around on their axles. It may work with standard bolts, but it won't be as good as it can be. Why introduce a source for errors when it's not necessary?
Re: Delta pulley and idler dimensions question December 07, 2015 09:11PM |
Re: Delta pulley and idler dimensions question December 08, 2015 05:10AM |
Re: Delta pulley and idler dimensions question December 08, 2015 05:21AM |
Re: Delta pulley and idler dimensions question December 11, 2015 04:28PM |
Re: Delta pulley and idler dimensions question December 11, 2015 04:37PM |
jaguarking11
I run 20T pulleys on my delta with 5mm id flanged bearings in a sandwitch. It works, however I am not happy with the arangement. I would like to run a 20T pulley with built in bearings, however I have not found any yet.
With that said, I still run rubber belts even with a heated chamber and 45-50C in there they seem to have settled down. I think a redesign of the idler side of a delta is necessary.
Re: Delta pulley and idler dimensions question December 11, 2015 04:47PM |
Re: Delta pulley and idler dimensions question December 11, 2015 05:20PM |
dc42
The toothed belt running on the smooth pulley is one of the noisiest components of my delta. I think it excites the resonant frequency of the belt at some speeds. That's why I want a better solution.
Re: Delta pulley and idler dimensions question December 12, 2015 01:59PM |
Re: Delta pulley and idler dimensions question December 13, 2015 11:46AM |
Re: Delta pulley and idler dimensions question December 13, 2015 01:02PM |
voi9viper
...The extruder is far less accurate, and I don't see huge efforts being made in that area yet, like feed forward pressure control..
Re: Delta pulley and idler dimensions question December 13, 2015 01:05PM |
Re: Delta pulley and idler dimensions question December 13, 2015 01:28PM |
voi9viper
I just hate imprecission too. syncromesh as in trasmissions? Or is it something new, which I suspect if patents apply. I'm dating myself, but my 71 firebird had a syncromesh tranny I think.
Re: Delta pulley and idler dimensions question December 15, 2015 02:39PM |
realthor
jaguarking11
I have considered 20T GT2 pulley with 8mm bore and 2x MR84ZZ (4x8x3mm) bearings but I have decided that inserting those miniature bearings in the bore was too complicated and opted out for 2 flanged F694ZZ (4x11x4mm). The difference in diameter from a 20T pulley with the belt ontop is 0.3 or 0.4mm when you put the belt riding on the bearings with the teeth on the smooth surface of the bearing's OD.
I also believe that this resulting smooth pulley will be quieter than a toothed pulley but I don't know by how much (a good read here: http://www.pfeiferindustries.com/troubleshooting/timing-belt-unusual-excessive-noise.html).
I guess I'll see when they arrive.
Why are you unhappy of that arrangement? Did you notice any loss in quality on the prints?
Re: Delta pulley and idler dimensions question December 15, 2015 02:44PM |
realthor
voi9viper
No idea how old this is but this is it:
Re: Delta pulley and idler dimensions question December 15, 2015 03:45PM |
Re: Delta pulley and idler dimensions question December 16, 2015 02:20AM |
Re: Delta pulley and idler dimensions question December 16, 2015 04:31AM |
Re: Delta pulley and idler dimensions question December 16, 2015 04:42AM |
Re: Delta pulley and idler dimensions question December 16, 2015 05:09AM |
dc42
If you have a half twist over a length of the belt that varies as in your second diagram, then the belt tension will vary with that length, and hence with carriage position. So the arrangement in the third diagram is better. This also lets you lock the teeth of the belt together in the carriage, which avoids the tension in the belt putting stress on the printed carriage parts. RepRapPro does this in the X carriage of their Ormerod printer.
Re: Delta pulley and idler dimensions question December 16, 2015 05:18AM |
realthor
dc42
I don't know if there is a way to securely stitch/clamp/bolt two sections of belt so I can cut 20mm of belt, reverse it and clamp/stitch/whatever to the other length of belt. This solution might be too stretched to work an i might opt for the spectra-belt combo instead.
I assume that 20mm section will never have to run over a pulley, so that it can be rigid. I suggest you lock the teeth of the two sections together, then hold them together in one of several ways:
- epoxy them in that position;
- clamp them between two small metal plates;
- print a plastic part with a slot in it, and push the belts into that slot - as on the Ormerod X-carriage.
