large diameter heated-bed design December 06, 2015 08:03PM |
Re: large diameter heated-bed design December 06, 2015 10:52PM |
Re: large diameter heated-bed design December 07, 2015 03:52AM |
Re: large diameter heated-bed design December 07, 2015 04:54AM |
Re: large diameter heated-bed design December 07, 2015 07:16AM |
Re: large diameter heated-bed design December 07, 2015 09:54AM |
Re: large diameter heated-bed design December 10, 2015 03:11PM |
Re: large diameter heated-bed design December 10, 2015 03:14PM |
That is why there is a small disk of cork (sandwiching a foil layer) under the thermistor. Didn't help much. I tried moving the sensor to a spot just outside of the heater (plate extends out by about 1" bigger radius) and got a huge temp in the middle. I just don't have good heat transfer.Quote
mandrav
I don't have much experience with this setup so take this with a grain of salt
I would not put the thermistor in direct contact with the heater. The reason being that you want the temperature of the aluminum bed reported, not that of the heater (the latter getting really hot really fast, I would guess).
With that in mind, I 'd test with the thermistor on a corner of the aluminum bed (not touching the heater).
Re: large diameter heated-bed design December 10, 2015 03:16PM |
Re: large diameter heated-bed design December 10, 2015 03:21PM |
I forgot that one other difference between this and my original Mini Kossel PCB heat plate was a layer of thermal paste across the whole thing.Quote
jaguarking11
I use cheap thermal paste between bed and 2mm heat spreader and thermal paste between spreader and glass. The bed gets into the 100c range pretty good.
(I will be looking for a thermal-adhesive to fix the problem)How is your silicone heater contacting/attached to the upper side (metal plate)? I found out this problem because I tried to print ABS for the first time and jacking the command to well above 100 C didn't seem to be enough. My 10mm cube was all warped!Quote
dc42
@shadowphile, it's very difficult to measure the temperature on top of glass using a thermocouple because of the insulating properties of the glass, the tiny contact area between the thermocouple and the glass, and the heat carried away by the thermocouple leads. My advice is to set the bed temperature about 10C higher than you actually want and not worry about it. I print on 4mm thick float glass plates and I use indicated temperatures of 70C for printing PLA and 120C for ABS.
I have thicker insulation than you do (8mm cork), however the main benefit is to avoid heating the electronics under the bed.
Re: large diameter heated-bed design December 10, 2015 06:55PM |
shadowphile
Re: large diameter heated-bed design December 10, 2015 07:35PM |
That is exactly my original build. I thought a 500W heater would be overkill, although all it should improve is heat-up speed. It was a good deal though.Quote
dc42
shadowphile
I stuck the silicone heater to the underside of the 6mm aluminium plate using the adhesive sheet that came already attached to it.
Re: large diameter heated-bed design December 10, 2015 10:19PM |
You will lose temperature where the glass is not over the heater, of course.|
Re: large diameter heated-bed design December 11, 2015 03:46AM |
shadowphile
I agree that a metal plate would solve all heat transfer issues, just haven't been ready to discard my investment in glass and metal and kapton are easy to scratch. Kapton is expensive, especially in large sheets.
Re: large diameter heated-bed design December 24, 2015 07:08PM |
Re: large diameter heated-bed design December 24, 2015 07:19PM |
Re: large diameter heated-bed design December 30, 2015 10:56AM |
Re: large diameter heated-bed design December 30, 2015 12:25PM |
