New Hall endstop sensor design - views sought
Posted by dc42
December 11, 2015 08:32AM
I intend to manufacture a small endstop switch board with am modern SMD Hall effect switch on it. The output will be low impedance in the not-triggered condition for high noise immunity, and there will be an LED on the board to indicate power and triggering. It will be proof against short circuited outputs and miswiring. It will be compatible with both 3.3V and 5V electronics.
The electrical design is done, but I need to finalise the mechanical design. I would like them to be easy to use on any delta, and to sacrifice little or no build height. My current plan is that they would normally be attached to the side of the tower extrusions and triggered by a magnet on the side of the carriage. When using wheeled carriages, there are usually 3 wheels; so if the endstop board is placed on the side with just one wheel, it will take up very little space as in this mock-up (this is not the actual PCB I will use, it will be smaller):
Does anyone have any other suggestions for a good mounting location and orientation that has little or no impact on build height?
Re: New Hall endstop sensor design - views sought
December 12, 2015 05:22AM
Dave
I will have a set when they are ready.
For me I can probably change things around to take whatever mounting you come up with.
On my more recent builds my endstop switches are mounted as yours are but my original delta they are mounted where you have the board positioned.
the new ones are using HIWIN Type linear rails tho so I would need to probably glue the magnets to the carriers in a suitable location (Will have to think on and make a 3 wire loom for them when I wire it up)
Doug
September 11, 2016 10:47PM
Are these derived from your work?
[www.ebay.co.uk]
[www.ebay.co.uk]
I'm thinking of trying to implement these hall sensors somewhere in the design, I've noticed gimbal motors are now using these as a way to improve the stabilization in conjuntion with newer 32bit controlers(though they are much more expensive $20 for the hall sensor board), [www.aliexpress.com]
so I was wondering if they could be used to also increase or count steps in a stepper motor for some kind of closed loop control..
perhaps thats not the way they work, just a thought.
Edited 2 time(s). Last edit at 09/12/2016 06:03AM by MechaBits.
September 13, 2016 05:40AM
No, those are not derived from anything by me. I swill be using 3.3V SMD Hall sensors.
September 13, 2016 09:18AM
@Dc42
Perhaps try putting the board horizontal instead of vertical to maximize vertical movement. My second idea is to have just the 3 sensors mounted at the top and 1 board down below. That would make it even smaller where ever you mount it.
September 13, 2016 12:19PM
Thanks, but the board will be very small anyway. The main design issue is what mounting arrangements to make for it.
September 13, 2016 12:54PM
So your sensor would be better than the ones available for £1, I dont like the boards where the sensor is sticking out on legs, so your smd improves on those.
