First test print failure December 13, 2015 12:48PM |
Re: First test print failure December 13, 2015 12:59PM |
Re: First test print failure December 13, 2015 01:00PM |
Re: First test print failure December 13, 2015 01:21PM |
dc42
Did you set the motor current back to a normal value after initial commissioning? If T3P3 is still shipping motors with 1.68A current rating, then I suggest 1000mA for the towers. The extruder may not need as much.
voi9viper
is just one corner too low, or is that from the photo?
Re: First test print failure December 13, 2015 01:34PM |
Re: First test print failure December 13, 2015 01:36PM |
Re: First test print failure December 13, 2015 01:45PM |
Re: First test print failure December 13, 2015 02:30PM |
Re: First test print failure December 13, 2015 04:03PM |
Re: First test print failure December 13, 2015 06:52PM |
Re: First test print failure December 14, 2015 05:40AM |
Re: First test print failure December 15, 2015 03:51PM |
Re: First test print failure December 15, 2015 04:13PM |
Re: First test print failure December 15, 2015 04:25PM |
MightyMouth
OK so I increased the probe trigger height from .95 to 1.0 but now it seems to not stick at all as if it is starting higher than before.
Re: First test print failure December 15, 2015 04:33PM |
