Can a smooth rods only towers printer be stable enough? December 13, 2015 03:05PM |
Re: Can a smooth rods only towers printer be stable enough? December 13, 2015 04:16PM |
Re: Can a smooth rods only towers printer be stable enough? December 14, 2015 07:49PM |
Re: Can a smooth rods only towers printer be stable enough? December 15, 2015 03:56AM |
Re: Can a smooth rods only towers printer be stable enough? December 15, 2015 04:06AM |
Re: Can a smooth rods only towers printer be stable enough? December 15, 2015 05:25AM |
pkm
Well my delta has 16mm rods and it's very stable (200x200mm print size)
epicepee
I bolted some Home Depot aluminum angles diagonally from top extrusions to bottom extrusions on my expanded Kossel Mini. I guess it reduces volume a bit, but it's quite minor. And I can sit on the thing while it prints. Highly recommend.
Re: Can a smooth rods only towers printer be stable enough? December 15, 2015 06:14AM |
The problem is that if your rigidity is low then the printer will have lower resonant frequency. If this frequency is comparable with the print head oscillations when printing small infills then you will have a problem. The printer head can easily generate frequency at about 200 Hz at rather common accelerations of 7g. Single 70 cm long Ø 8 mm smooth rod will have resonant frequency the area of low tens of Hz. Of course this is a very rough computations but it does not sound promising for Ø 8 mm rods. But Ø 8 mm smooth rods have also a problem of dynamic bending in the range of about 0.1 - 0.2 mm so they are just not suitable even inside a rigid frame.Quote
dc42
I see no reason in principle why smooth rods alone cannot provide sufficient stability and rigidity. The key is securing them to the triangle base and top in a stable and rigid manner. I doubt whether this can be done adequately in a large printer by the use of printed ABS parts.
Re: Can a smooth rods only towers printer be stable enough? December 15, 2015 07:12AM |
hercek
dc42
But one can get much thicker smooth rods easily and aluminum extrusions should do much better too.
Re: Can a smooth rods only towers printer be stable enough? December 15, 2015 08:34AM |
dc42
hercek
dc42
8mm does seem rather thin for this application. I was thinking of 12mm smooth rods, like the ones on my Ormerod. The RepRapPro Fischer kit uses 8mm rods, but they are only 426mm long.
Re: Can a smooth rods only towers printer be stable enough? December 15, 2015 06:08PM |
hercek
Re: Can a smooth rods only towers printer be stable enough? December 15, 2015 06:26PM |
realthor
...Now the working length for this particular printer is about 270mm so the rest 240mm of the unsupported rod (the length below the carriages in the previous link) is something that design-wise is a mistake....
Re: Can a smooth rods only towers printer be stable enough? December 15, 2015 06:51PM |
dc42
The movement speed when running delta firmware on an Arduino Mega is limited by the speed at which it can calculate and generate stepper motor pulses. The acceleration that is possible is limited not by firmware, but by mechanics, effector mass. motor inertia, and supply voltage to the drivers.
Re: Can a smooth rods only towers printer be stable enough? December 16, 2015 05:18AM |
Re: Can a smooth rods only towers printer be stable enough? December 16, 2015 05:57AM |
hercek
CPU power of your controller will determine the maximum speed you can run. The other important limiting factors for speed are stepper inductance and the driving voltage and how quickly you can cycle your stepper drivers together with microstepping used.
Re: Can a smooth rods only towers printer be stable enough? December 16, 2015 08:13AM |
realthor
So far we have:
1) Maximum speed dependent on CPU throttling => Top speed limited by CPU power;
2) Maximum acceleration dependent on motor specs, voltage in the steppers
3) Maximum acceleration dependent on effector mass, due to the compound effect of rods deflection, mechanical positional overshooting (backlash?) and belt elasticity (=> backlash, overshooting)
Am I correct with these conclusions?
Re: Can a smooth rods only towers printer be stable enough? December 16, 2015 08:48AM |
dc42
realthor
I think you will find that when the effector is at the edge of the bed opposite one of the towers, the unsupported length below the carriage on that tower is somewhat less than 240mm. But IMO your idea is sound, if there is still significant unsupported length below it.
Re: Can a smooth rods only towers printer be stable enough? December 16, 2015 11:06AM |
realthor
So far we have:
Re: Can a smooth rods only towers printer be stable enough? December 16, 2015 03:18PM |
Re: Can a smooth rods only towers printer be stable enough? December 16, 2015 05:34PM |
Re: Can a smooth rods only towers printer be stable enough? December 16, 2015 06:33PM |
Re: Can a smooth rods only towers printer be stable enough? December 16, 2015 06:38PM |
Re: Can a smooth rods only towers printer be stable enough? December 16, 2015 06:55PM |
LarsK
Oh. This is a hobby. I also make a lot of stuff just because it looks interesting/ fun to do. Just think careful about why your doing it and don't forget to have fun hope that negates the somewhat negative wibe of before
Re: Can a smooth rods only towers printer be stable enough? December 17, 2015 04:01AM |
realthor
About CPU throttling via complex calculations I can't do much about but changing the borad (will not do for the time being).
About the motors, again nothing, I have them already, will use what I have. I will change the stepper drivers though (A4498 to DRV8825) although 32 microstepping will not increase the quality but might lower the noise at least.
Re: Can a smooth rods only towers printer be stable enough? December 17, 2015 11:20AM |
Re: Can a smooth rods only towers printer be stable enough? December 17, 2015 01:03PM |
Re: Can a smooth rods only towers printer be stable enough? April 27, 2018 04:02PM |
Re: Can a smooth rods only towers printer be stable enough? April 27, 2018 07:13PM |
Re: Can a smooth rods only towers printer be stable enough? April 28, 2018 02:53AM |
Re: Can a smooth rods only towers printer be stable enough? April 29, 2018 07:18AM |
MKSA
Quality smooth rod is hardened steel and you can't thread . Anyway, better secure it in a hole, a slit and a bolt to squeeze it, rather standard method.
Re: Can a smooth rods only towers printer be stable enough? April 29, 2018 09:14AM |
Gheorghe
@Mr. David
That Fisher tip was gold, platinum even. Some of my plans changed a bit thanks to Fisher. I'm almost embarrassed to use his design in helping mine. So much work, detailed explained pictures, .stl , cad, and so on.
It shorten my work A LOT.
