Volumetric Calibration: can most of the possible Delta construction errors be inferred from a calibration print? December 20, 2015 08:49PM |
Re: Volumetric Calibration: can most of the possible Delta construction errors be inferred from a calibration print? December 20, 2015 10:24PM |
Re: Volumetric Calibration: can most of the possible Delta construction errors be inferred from a calibration print? December 20, 2015 11:58PM |
grat
A plumb line should be able to determine that, and a spirit level should be able to tell the frame is horizontal.
grat
The carriages should be at 120 degrees to each other, which means a piece of string or a straight edge should bisect the horizontal across from the carriage.
Don't worry, I am not thinking like that, i am grateful you guys take the time to answer to my overcomplicated and unnecessarily (maybe) philosophical/perfectionist scenarios.Quote
grat
This isn't intended as bragging-- quite the opposite.
grat
Beware the law of diminishing returns. The more precise and rigid your printer is, the more expensive and difficult it's going to be to design, fabricate, and assemble.
Re: Volumetric Calibration: can most of the possible Delta construction errors be inferred from a calibration print? December 21, 2015 12:56AM |
Re: Volumetric Calibration: can most of the possible Delta construction errors be inferred from a calibration print? December 21, 2015 04:13AM |
Re: Volumetric Calibration: can most of the possible Delta construction errors be inferred from a calibration print? December 21, 2015 04:47AM |
Re: Volumetric Calibration: can most of the possible Delta construction errors be inferred from a calibration print? December 21, 2015 08:14AM |
Re: Volumetric Calibration: can most of the possible Delta construction errors be inferred from a calibration print? December 21, 2015 11:13AM |
realthorQuote
grat
Hmm, don't follow the wording of that explanation. Towers angles can quite easily be tested in several ways from which the easiest would be a calibration print and the measurement of the resulting 120 degree lines with a protractor. Maybe there are several other ways, like you suggest, but I fail to see the way you explain.
Re: Volumetric Calibration: can most of the possible Delta construction errors be inferred from a calibration print? December 21, 2015 11:19AM |
You are almost for sure wrong. Search for papers on calibration of 6-DOF parallel robots. Those things can be calibrated to the precision better than 1µm. Our delta printers are just limited variations of those robots. I believe the only problem is that nobody bothered to implement more general calibration for linear delta printers.Quote
realthor
Nevertheless after much thinking I am slowly concluding that even decent physical/mechanical calibration is almost impossible, not talking about perfect calibration. I can't even imagine how to measure twisting between the bottom platform and the top platform or slight angle deviation between towers... and there are many more errors that can be factored in.
Re: Volumetric Calibration: can most of the possible Delta construction errors be inferred from a calibration print? December 21, 2015 02:41PM |
hercek
realthor
Obviously, you are interested. You may want to give it a shot. I bet the community would appreciate it :-)
Re: Volumetric Calibration: can most of the possible Delta construction errors be inferred from a calibration print? December 21, 2015 07:47PM |
Re: Volumetric Calibration: can most of the possible Delta construction errors be inferred from a calibration print? December 21, 2015 08:01PM |
the_digital_dentist
The thing that makes me hesitate to build a delta printer is the difficulty of alignment and diagnosing problems. I have thought about how to ensure that the guide rails are 120 degrees apart, and parallel and it seems difficult. I think I can get the guide rails parallel (using linear guides), but ensuring 120 degrees spacing and no twist is tricky. Also, making things adjustable so they can be positioned parallel, 120 degrees apart, and twist free is a little tricky.
Re: Volumetric Calibration: can most of the possible Delta construction errors be inferred from a calibration print? December 22, 2015 02:56AM |
Re: Volumetric Calibration: can most of the possible Delta construction errors be inferred from a calibration print? December 22, 2015 03:18AM |
Re: Volumetric Calibration: can most of the possible Delta construction errors be inferred from a calibration print? December 22, 2015 03:46AM |
hercek
dc42 has some web page too (if maxima is too tough for you). IFAIK, the only problem with the web page is that the number of probing points is limited. The less mechanically sound your printer is the more probing points you need.
Re: Volumetric Calibration: can most of the possible Delta construction errors be inferred from a calibration print? December 22, 2015 09:36AM |
Good! Thanks for the correction. So I can just point all people directly to your web page :-)Quote
dc42
There is no limit to the number of probe points you can enter in the web page. Perhaps you are thinking of the version of the algorithm built in to RepRapFirmware, which is currently limited to 16 points.
Re: Volumetric Calibration: can most of the possible Delta construction errors be inferred from a calibration print? December 22, 2015 10:23AM |
Re: Volumetric Calibration: can most of the possible Delta construction errors be inferred from a calibration print? December 22, 2015 10:52AM |
Re: Volumetric Calibration: can most of the possible Delta construction errors be inferred from a calibration print? December 22, 2015 11:43AM |
If your printer does not have any play then you do not need more than 8 points. Dejay Rezme did simulations to show this. It is possible that 7 points may be enough but probably with a different system then I used to calculate the calibration parameters. Dejay's simulations indicated that 7 points are not always enough for my system to converge well. It is kind of strange since only 7 parameters are optimized therefore 7 points should be enough. But the simulations shown it is better to use 8 points for good convergence. Of course, if you do not optimize all 7 parameters then smaller number of points is needed.Quote
realthor
Is there a reason why one would want more than 16 points? Even 16 points seem many to me... I mean at least you should have a fairly flat bed, and if it's flat then an inclined bed can be inferred from an even smaller number of points.
Re: Volumetric Calibration: can most of the possible Delta construction errors be inferred from a calibration print? December 22, 2015 02:13PM |
hercek
hercek
Re: Volumetric Calibration: can most of the possible Delta construction errors be inferred from a calibration print? December 22, 2015 03:31PM |
Any kind of play. The most common kinds are:Quote
realthor
What kind of play are you talking about? I'm guessing that you might be referring to play in the towers during effector moves if the connectors between alu profiles are plastic. Also play between pulley and belts as you put it although I don't know what that means -maybe you can shed some light on that.
The same as di42's calibration. It is fixing:Quote
realthor
What are your 7 parameters that are being optimized by probing bed locations and are there other parameters that can be taken into consideration? I am mostly interested if any calibration procedure can take as input volume specific errors such as leaning towers, twisted frame, maybe others I can't imagine. I get the feeling from the comments here that volume calibration is not something that delta owners concern themselves with.
Re: Volumetric Calibration: can most of the possible Delta construction errors be inferred from a calibration print? December 22, 2015 03:51PM |
hercek
realthor
Re: Volumetric Calibration: can most of the possible Delta construction errors be inferred from a calibration print? December 22, 2015 07:15PM |
dc42
realthor, if the printer geometry were perfect apart from the tower positions then there would be no point in using additional points. In practice there are other errors caused by leaning towers, rods that are not quite parallel etc. In this case it is worth using more points, both to get a flatter printing surface on average, and to get an idea of how flat the printing plane is.
dc42
