Watercooled Tri-Hotend December 23, 2015 10:41AM |
). I used 3.5mm spacers (pic) to achieve the whole possible gimbaling motion of the IGUS KBRM-03MH bearing.
Re: Watercooled Tri-Hotend December 23, 2015 02:19PM |
Re: Watercooled Tri-Hotend December 23, 2015 04:34PM |
Re: Watercooled Tri-Hotend December 23, 2015 05:36PM |
Re: Watercooled Tri-Hotend December 24, 2015 07:26AM |
Was more speaking in XY vs Z.Quote
Dragobert
I about the printing: I know. but since i redesigned the Rostock to make it cheaper for me, I have some trouble printing good parts. After all, I'm not a man whose in love with electronics =/
About the build space: I think that's not that much. From the centerplane (mid of screws to the rods) to the bottom of the heater block without nozzle it's 21mm. Is that much? Unfortunately I don't have much for comparison except a standard hotend (which i never used).
Thanks for the answers so far, folks! =D
Cheers
Re: Watercooled Tri-Hotend December 26, 2015 01:11AM |
Re: Watercooled Tri-Hotend December 26, 2015 02:08AM |
Re: Watercooled Tri-Hotend December 28, 2015 10:13AM |
xile6
All 3 nozzle look to make a tri with about 20-25mm legs.
/quote]
All 3 nozzles are on a circle with a 15mm radius, which cannot be (significantly) smaller, because of the heat distribution between the nozzles trough the plate (which will be aluminum from now on).
Sorry for the late answer, I somehow overlooked your post.
Also the system with silicone hoses and without the brass hose adapters works just fine and the Wim3rl is now down to exactly 60g!
Edited 1 time(s). Last edit at 12/28/2015 10:14AM by Dragobert.
Re: Watercooled Tri-Hotend December 30, 2015 12:38PM |
