Hi folks! I am trying to get my newly built Folger Tech Kossel 2020 up and running with Repetier firmware and using Repetier Host. When I home all, the axes rise to the end stops as expected, home, but then descend 40mm. The Z counter still reads zero, and therefore my bed is 40mm higher than the printer thinks it is.
This does not happen in Marlin. What should I be looking for? I am using the configuration files from paul_delta.
Thanks for any help, this has been a challenge to get running.
