Kossel firmware motor problem January 25, 2016 01:55PM |
Re: Kossel firmware motor problem January 25, 2016 03:04PM |
Re: Kossel firmware motor problem January 25, 2016 03:47PM |
Re: Kossel firmware motor problem January 25, 2016 05:23PM |
Re: Kossel firmware motor problem January 25, 2016 06:03PM |
Re: Kossel firmware motor problem January 25, 2016 10:20PM |
saintcady
Ok, checked those lines in the firmware and they match what I have. I also checked each endstop by manually holding them down one at a time and sending m119. They all read triggered when held, open when not.
The board is a mega 2560 with a RAMPS. X and Z motors are moving when directed, Y is not.
Re: Kossel firmware motor problem January 25, 2016 11:24PM |
Re: Kossel firmware motor problem January 26, 2016 03:19AM |
Re: Kossel firmware motor problem January 26, 2016 12:53PM |
Re: Kossel firmware motor problem January 26, 2016 02:10PM |
Re: Kossel firmware motor problem January 26, 2016 05:43PM |
Repier37
I had a look and didn't see anything obvious.
The only thing might be :
#define min_software_endstops true // If true, axis won't move to coordinates less than HOME_POS.
#define max_software_endstops false // If true, axis won't move to coordinates greater than the defined lengths below.
I was using inverted false-true value when I was using marlin on my rostock.
But I guess that your X motor wouldn't work either...
Anyway, if you want to give it a try here are the value I was using
#define min_software_endstops false
#define max_software_endstops true
I think it worth the try.
Re: Kossel firmware motor problem January 27, 2016 02:07PM |
Re: Kossel firmware motor problem January 27, 2016 05:04PM |
Re: Kossel firmware motor problem January 27, 2016 05:24PM |
Either that or something weird in the eeprom.Quote
saintcady
It's better, but I'm not sure why.
I installed the Prusa Firmware to check if the motor worked, which it did. I reloaded a fresh install of the Delta firmware and now it works. I guess I must have had a weird change somewhere in the firmware I was using before - it's possible a student changed something and forgot to tell me.
Thanks for your help everyone!
Re: Kossel firmware motor problem February 02, 2016 11:07AM |
