Help Calibrating Delta - Printing issue February 02, 2016 10:56PM |
Re: Help Calibrating Delta - Printing issue February 02, 2016 11:21PM |
Re: Help Calibrating Delta - Printing issue February 03, 2016 12:22AM |
Re: Help Calibrating Delta - Printing issue February 03, 2016 02:53AM |
Re: Help Calibrating Delta - Printing issue February 03, 2016 03:50AM |
n9jcv
Yes, exactly, I feel like it is a wavy washer but it is glass, and I have checked and it is flat, at least to the best of my tools for measuring. I hooked the printer up to pronterface. I told it to go down 20 mm and it went down 19.97 very close I then homed and told it to go 100 and it went 99.97mm so to the best of my measuring the steps are correct.
this is from my config file
I am running ramps 1.4 Marlin, 8825 drivers 1.7A 1.8deg nema 17 motors
The size of the circles I printed came out as expected, so I do not see how it is the steps that are wrong. But I can not figure it out.
Below is a pic of a circle from the center 1 layer
I had to put a white paper behind it so you could see what is happening
It is like it has a high spot thru the center
Pic
Re: Help Calibrating Delta - Printing issue February 03, 2016 03:55AM |
