My first build, all metal delta "The Imp" February 10, 2016 05:34PM |
Re: My first build, all metal delta "The Imp" February 10, 2016 08:26PM |
Re: My first build, all metal delta "The Imp" February 10, 2016 11:22PM |
Re: My first build, all metal delta "The Imp" February 11, 2016 01:25AM |
Re: My first build, all metal delta "The Imp" February 11, 2016 02:59AM |
Re: My first build, all metal delta "The Imp" February 11, 2016 10:49PM |
Re: My first build, all metal delta "The Imp" February 11, 2016 11:25PM |
GroupB
Today I finish installing the top frame and top bearing are in place, now im trying to install the bottom bearing and that where the fun start... because of the off specs bottom shaft with too long thread at the end (.375" and suppose to be .3 " ), I have to find a way to shorten my bearing housing , I cannot just move them closer because there is the 20X40 between the 2 housing and in my original design they both touch the beam on each side. Drilling deeper to move the bearing look like a good solution but because I slot them I don't know if it gonna work, if its not working I will make 3 new housing I guess.
GroupB
Tomorrow Im gonna make the carbon arms, any advice on cutting those ? metal handsaw ? dremel cutting disk ? I know its a heath issue and I dont have a large enough container to cut them submerge in water so im gonna cut them outside with glove a mask.
is carbon fiber become brittle in cold weather ? like - 20 celcius
Re: My first build, all metal delta "The Imp" February 11, 2016 11:29PM |
Re: My first build, all metal delta "The Imp" February 12, 2016 12:24AM |
Re: My first build, all metal delta "The Imp" February 12, 2016 01:30PM |
Re: My first build, all metal delta "The Imp" February 14, 2016 10:29PM |
Re: My first build, all metal delta "The Imp" February 15, 2016 02:47AM |
Re: My first build, all metal delta "The Imp" February 15, 2016 01:01PM |
Re: My first build, all metal delta "The Imp" February 17, 2016 07:50PM |
Re: My first build, all metal delta "The Imp" February 18, 2016 03:48PM |
Re: My first build, all metal delta "The Imp" February 19, 2016 09:10PM |
Re: My first build, all metal delta "The Imp" February 19, 2016 09:56PM |
Re: My first build, all metal delta "The Imp" February 22, 2016 06:49PM |
Re: My first build, all metal delta "The Imp" February 22, 2016 07:15PM |
; Configuration file for The Imp ; Communication and general M111 S0 ; Debug off M550 TheImp ; Machine name and Netbios M551 1234 ; Machine password (FTP) M540 P0xBE:0xEF:0xDE:0xAD:0xFE:0xED ; MAC Address ;*** Adjust the IP address and gateway in the following 2 lines to suit your network M552 P0.0.0.0 ; IP address (0 = use DHCP) M554 P192.168.1.1 ; Gateway M553 P255.255.255.0 ; Netmask M555 P2 ; Set output to look like Marlin M575 P1 B57600 S1 ; Comms parameters for PanelDue G21 ; Work in millimetres G90 ; Send absolute coordinates... M83 ; ...but relative extruder moves ; Axis and motor configuration M569 P0 S1 ; Drive 0 goes forwards M569 P1 S1 ; Drive 1 goes forwards M569 P2 S1 ; Drive 2 goes forwards M569 P3 S1 ; Drive 3 goes forwards M569 P4 S1 ; Drive 4 goes forwards M569 P5 S1 ; Drive 5 goes forwards M574 X2 Y2 Z2 S0 ; set endstop configuration (all endstops at high end, active low) ;*** The homed height is deliberately set too high in the following - you will adjust it during calibration M665 R174.6 L350.0 B152.0 H256.0 ; set delta radius, diagonal rod length, printable radius and homed height M666 X0 Y0 Z0 ; put your endstop adjustments here, or let auto calibration find them M92 X160 Y160 Z160 ; Set axis steps/mm M201 X1000 Y1000 Z1000 E1000 ; Accelerations (mm/s^2) M203 X20000 Y20000 Z20000 E3600 ; Maximum speeds (mm/min) M566 X1200 Y1200 Z1200 E1200 ; Maximum instant speed changes mm/minute ; Thermistors ;*** If you have a Duet board stickered "4.7K", change R1000 to R4700 to the following M305 commands M305 P0 T100000 B3950 R4700 H30 L0 ; Put your own H and/or L values here to set the bed thermistor ADC correction M305 P1 T100000 B3950 R4700 H30 L0 ; Put your own H and/or L values here to set the first nozzle thermistor ADC correction M305 P2 T100000 B3950 R4700 H30 L0 ; Put your own H and/or L values here to set the second nozzle thermistor ADC correction M570 S180 ; Hot end may be a little slow to heat up so allow it 180 seconds ; Tool definitions M563 P0 D0 H1 ; Define tool 0 G10 P0 S0 R0 ; Set tool 0 operating and standby temperatures ;*** If you have a dual-nozzle build, un-comment the next 2 lines ;M563 P1 D1 H2 ; Define tool 1 ;G10 P1 S0 R0 ; Set tool 1 operating and standby temperatures M92 E663:663 ; Set extruder steps per mm ; Z probe and compensation definition ;*** If you have an IR zprobe instead of a switch, change P4 to P1 in the following M558 command M558 P0 X0 Y0 Z0 ; Z probe is a switch and is not used for homing any axes G31 X0 Y0 Z4.80 P500 ; Set the zprobe height and threshold (put your own values here) ;*** If you are using axis compensation, put the figures in the following command M556 S78 X0 Y0 Z0 ; Axis compensation here M208 S1 Z-0.2 ; set minimum Z ; T0 ; select first hot end
Re: My first build, all metal delta "The Imp" February 22, 2016 08:01PM |
Re: My first build, all metal delta "The Imp" February 22, 2016 08:29PM |
Re: My first build, all metal delta "The Imp" February 22, 2016 10:38PM |
Re: My first build, all metal delta "The Imp" February 23, 2016 02:36AM |
Re: My first build, all metal delta "The Imp" February 23, 2016 04:16AM |
Re: My first build, all metal delta "The Imp" February 23, 2016 05:12AM |
Re: My first build, all metal delta "The Imp" February 23, 2016 05:58AM |
Re: My first build, all metal delta "The Imp" February 23, 2016 06:42AM |
Re: My first build, all metal delta "The Imp" February 23, 2016 06:47AM |
Re: My first build, all metal delta "The Imp" February 23, 2016 07:55AM |
GroupB
I tried what you said but right after I send the m98 Pconfig.g command , I recv: OK , then I send 2 M105 and got no recv... it hang
Re: My first build, all metal delta "The Imp" February 23, 2016 08:40AM |
